Got the switch plate in and installed
XTC Power Products Center Console Switch Plate for Honda Talon 1000 SP-6SW-HT https://www.amazon.com/dp/B07TLHC3GS/?tag=sxsweb24-20
After running cable from the rear for the winch and dual battery, I found that Honda had already done that. They even ended right by my battery isolator
The front winch has an in cab switch already and I was thinking about how I could have that same switch run front or rear with a selector switch.
I'd like to have the sector switch be a 3 way with off in the middle also. Right now the switch is live with the key, which I'm not to fond of, since I have young kids that like to switch switches and press buttons. I did a momentary switch for the seltor switch also. That way there is a little safety built in.
This is how I did the wiring for the selector:
In | out (front)
In | out (to switch)
In | out (rear)
Control switch:
In (from selector)
Power
Out (from selector)
I know I could just add another switch and it'd be the same thing, but like I said, I'd like to add the little safer feature in of having an all off position.
This will be front winch in
Rear winch in
I'm sure you can imagine how out works.
I also added a good old fashioned plug for the rear
I also worked on sealing some of the air gaps in the firewall with some foam in the cowel space. As well as added the rear vents and ducting for the heater.
In | out (front)
In | out (rear)
Control switch:
In (from selector)
Power
Out (from selector)
Rear winch in
