P1000 Yet Another Pioneer 1000 Dual Battery Install - video
Lady01
Lady01
192
488
Midland Michigan
I have a question regarding the bus bars and relays. Is it possible to by pass them and just run a fuse box that has the neutral bar on it? I’m planning on getting the key on harness from the club store as well as the isolator. Then run the stinger straight to the fuse box. Is this an option or am I going to burn my sxs up?
Yes, that is how I have mine. THe Buss Bar is a great idea but I use the ones already provided on the fuse panel. The isue is that you will run multiple gnd/pwr wires to to/from the fuse block rather than to the buss bar... gets a little full.
TripleB
TripleB
21,175
184,095
Caryville, Tennessee
That's how I have mine wired up also. It's been working for 2 years now.
ACfixer
ACfixer
Global Warming Enthusiast
218
840
N/E Tennessee
I'm getting a fuse block with a built in pos+ and neg- buss and doing just that. Space is at a premium here!
Prntckt
Prntckt
1,106
7,726
Altoona, WI
  1. Talon X4
I installed a fuse block with a neutral buss in it and it worked great
20210120 210149
20210120 210228
ACfixer
ACfixer
218
840
N/E Tennessee
Rather than start another thread I thought I'd just piggyback on Bob's here.
Okay, this was as far as I could really go today. I'm waiting for a turn/horn kit, a dash panel and rocker set, a winch, along with some lighting so when that all gets here Tuesday-ish I'll be back on it. I do have a covered 6 circuit fuse block with a pos+ buss that I can install in the meantime as well. I used the rear push pin to lock down the stinger.
Honda 3
I wasn't having much luck getting the fusebox cover on after using the Bussman add-a-wire doohickey so II think I'll look the the schematic and power the stinger another way or use a master switch on my dash panel.
ACfixer
ACfixer
218
840
N/E Tennessee
You don't need a buss bar IMO Cajun. With the stinger and a fuse block you'll have two switched bolt down terminals, one on the stinger and one at the fuse block. You also have the other three at the hot side of the stinger, the battery terminal, and the isolator if you don't want it switched. I just didn't see a need for a separate buss.
Reactions: Worse1 and Lady01
Prntckt
Prntckt
1,106
7,726
Altoona, WI
  1. Talon X4
The positive lead from the fuse back is going to a stinger? What is the next thing behind you stinger that I’m assuming splits to the battery and the isolator?
Correct, The lead goes to a small buss that terminates wires from the battery under the seat, a wire from the isolator and a wire from the stinger. The separate busses are a convenience, not a necessity. They are nice IF you have the space. Fortunately I did.
I added some items that made my installation easier for me, and I found the space to do it by putting the second battery under the driver seat and using the second battery box space under the hood for a wiring panel. Definite not required, but I thought it made the installation easier in the long run. My installation had a few extra details that complicated the installation. I also wanted to make the wiring easily disconnected if I ever had to remove the front clip. My second battery is a full size 775CCA AGM battery mounted under the drivers seat.
20210125 182131
Battery tray under driver seat
20210212 183302
775 CCA AGM battery for aux, adding winch(es) next!
I ran a 1” flex conduit from under the hood to that location, and continued up the ROPS frame to an overhead console that I have my switch bank and stereo mounted in.
20210212 183401
1" conduit from under driver seat to overhead console
20210212 183414
20210212 183431
Overhead console with switch bank, stereo, dome lights and aux power outlets
20210120 154442
1" conduit routed from battery location to under the hood
I added the two busses as a convenient way to terminate the #6 AWG that I used for the high amperage cables. The terminal block provides easy connection to the overhead wiring console. I ran a few extra conductors for future additions
20210120 204725
I made a termination panel that fits in the second battery bay tightly and is secured in place with two 1/4-20 threaded rods to the bottom of the second battery box enclosure. The control wiring from the overhead console is terminated on the terminal block at the back of the panel
I didnt like the multiple cables crimped together on the positive battery terminal, and adding another cable from the battery to isolator made it difficult to terminate all of them on the battery, so I separated them and terminated them on a separate buss.
20210212 180501
I like how it turned out and there is unused wiring in place that allows for future changes and additions.
20210120 155219 20210120 204714 20210212 180453 20210212 180513 20210212 180528 20210212 180538 20210212 180609 20210212 183424
Lady01
Lady01
192
488
Midland Michigan
View attachment 254601View attachment 254603
View attachment 254584 View attachment 254587 View attachment 254593 View attachment 254595 View attachment 254596 View attachment 254597 View attachment 254598 View attachment 254602
Nice work, I have been thinking of adding a full size second battery under the seat area as well...you just inspired me!
Reactions: Worse1 and Prntckt
Prntckt
Prntckt
1,106
7,726
Altoona, WI
  1. Talon X4
I fastened the unistrut with 1-3/4” loop clamps from Mcmaster Carr to the frame rails under the seat compartment. The Stainless steel battery tray is from Amazon.
Spoonbill
Spoonbill
227
273
East TN
Greetings all - this is my first post - from West Chester, PA. Just joined a few weeks ago. Love seeing everyone and reading all of the great community knowledge! Just got our 2020 P1K-5 used with only 34 miles on it! The first thing I wanted to do was add the dual battery system for accessories, and I read all the threads and watched all the YouTube videos I could find - but I was still left with some confusion and questions. So I decided to do my own video to help me understand it better. Best way to learn a subject is have to explain it to someone else!
Thanks to JoeyL here on the forum for his wiring diagrams from other posts. I used those as inspiration.
Here is the YouTube link.
I have also attached my wiring diagrams.
Update 12/20/2020 - I have updated several diagrams. They now show relay post #s for the dual voltmeter plus additional relay and switch connections on page 2.
Enjoy!
rob
Good morning, Rob. I tried to open each of these and got nothing but jibberish which looks like some encryption. I‘ll try again on my laptop, but might want to check these out
Reactions: Lady01
ACfixer
ACfixer
218
840
N/E Tennessee
The videos seem to be working from my desktop and my phone Spoonbill, I think it's something on your end. I can access them with and without the VPN running.
Reactions: Lady01
ACfixer
ACfixer
218
840
N/E Tennessee
Any reason we can't remove one of those ridge/fin things on the air cleaner box folks?
Reactions: Lady01
Worse1
Worse1
145
554
Arizona
I did, no trouble so far View attachment 254969
Sent from my SM-G781U using Tapatalk
I did the same as @Wxbee and shaved off the fins. I used some strong velcro tape to stick it on there just make sure you clean it with alcohol before sticking on the velcro. No problems either. I used a Dremel to make the cuts using the circular blade/accessory tool.
5C61F732 83D5 403B A742 6931A2D9608E
