You are a Honda engineer....
GPR1500SC
GPR1500SC
857
2,355
North East MO
  2. Talon X LV
I intend to use my Talon on the farm.
Which would you choose to take over a chiseled field the Pioneer or a Talon?
Taking lunch or a certain tool the Talon will work fine, but that being said the Pioneer isn't leaving either we will use them both.
208,029
If people are buying Talons to do anything other than trail/dune ride or race because "cool factor", then that's on them for buying the wrong machine.
Common sense says you wouldn't buy a RZR, YXZ, X3 or KRX to do yard and farm work...
Maybe we just like to do yard work fast!
Bigshow
Bigshow
162
729
1. Lower the sweep on the front CVs to beable to turn front tires sharper.
2. 115HP on pump gas out of the engine.
3. fix rear suspension geometry.
4. better and relocate gauge cluster.
5. more room in cab.
267,222
I'd make it belt drive.
Crazy talk 672x372
267,222
All you Vivienne Engineers are so full of it 🤣 Half the " issues" brought up are not an issue with the 1000X version or a Pioneer1000, yall bought the wrong model based on bigger spec sheet numbers.
Divina de campo divina
42,130
I'd adopt a version of the Honda civic cvt for both the Talon and the P1k. CVT for those who want it and its advantages, but with fixed "shift points" emulating a 6 (or 7 or 8) speed for those who like ripping through the gears. And a manual diff lock on the talon for those who want it.
SLOWPOKE693
SLOWPOKE693
1,657
6,409
Somewhere in Texas
Tires are expensive, and driveline bind breaks s***.
Does any brand make a sport SxS with a selectable rear locker? What have you broken because of this rear "driveline bind"? Sounds to me like you bought the wrong type of machine for your actual use and that a Pioneer or Jeep would have been a better choice. No?
1HasBeen
274
672
Wickenburg, AZ
Polar-ass offered some RZRs with turf-saver rears. Not in the high zoot models IIRC.
