P1000 Post your homemade mods!
dale5740
dale5740
886
417
mt airy md
other than the factory accessories that everyone has mentioned already, i came up with a dust and heat buster that helps alot from under the bencj seat see pic. i used the insulation roll bubble wrap from home depot and cut a section to fit. View attachment 11502 View attachment 11503
how has the insulation under the seat done for u so far? does it make a big difference?
DTAGG
DTAGG
166
237
ST GEORGE UTAH/ACCORD LAKES SEVIER COUNTY UTAH
Yes. it cut some noise down , closed the gaps around the seat cushion to frame and i don't notice the heat like i did without it. now i am working on the center area between the bed and seat back to close those gaps off with insulation. hope to have a solution soon.
Delton
Delton
Honda Fanboy
9,967
31,485
Middle TN
I bet it helped some with the gear whine noise huh? Keep us posted on your progress as we are all fighting the heat lol
Reactions: pct
dale5740
dale5740
886
417
mt airy md
everyone says gear wine noise and I know its there but doesn't bother me a bit probably because my old rig pol 700 xp with 7k was wining its ass off when I sold it!!! lmao
Reactions: pct and Delton
Delton
Delton
Honda Fanboy
9,967
31,485
Middle TN
It don't bother me but I could hear the exhaust note alot better if it wasn't there lol
Reactions: pct
mystic1219
mystic1219
191
202
good idea that would work great for me cause with radio in dash not enough room for phone!! thanks
9d5db7500dcdac1a4382cc5fb4abe9f6
It can be done ;)
N
Ned
241
183
West Kentucky
DTAGG,
After looking at what you did under your seat, I went looking at the Home Depot website to see about the product you used. I can't seem determine which insulation you used, would you give me a bit more detail on that please?
Delton
Delton
Honda Fanboy
9,967
31,485
Middle TN
This started out as a temporary fix, but after getting them on, I like it. Won't help with cleanup but should keep some mud off of us due to those Evos sticking out past fenders. Removing/installing is a breeze with those plastic rivets. I accidentally ordered some 10mm ones and they are perfect for this.
IMG 20160405 125311244 800x450
IMG 20160405 125319401 HDR 800x450
nbomar
nbomar
4,416
17,854
Springdale, AR
View attachment 13040 View attachment 13041
Did you cut these yourself? What did you use?
What if you need to dump the bed?
Reactions: pct
Eltobgi
Eltobgi
4,599
15,186
North Dakota
1 self tapper & 4 bolts per side will have to be removed. I thought about using the plastic push rivets from the front but wanted a tighter connection. If the inconvenience becomes to much I will most likely replace with something more easily removed!
Reactions: dotman1
Yours does look good, I like the looks of it better than mine. Especially with the custom lettering. Just for your information, the plastic rivets have never failed me even when trailering at 65-70 miles an hour. I cut a slit in the extensions so that they could easily be removed. I cannot see a cut in yours, do you have to remove the roll cage bolts to get yours out?
It may not be a big deal for you, but I use the dump bed quite often around the homeplace. Congrats on a cool set up. And you know what they say, mockery is the highest form of flattery.
Eltobgi
Eltobgi
4,599
15,186
North Dakota
Thanks, but I believe you deserve all the credit! my design has the slit on the opposite end forty-fived toward the center. I recently installed the universal Rally Armor mud flaps on a vehicle and after seeing your design, came up with the idea. $25 dollars on eBay for a set of four.
Great job, I really like it.
Pioneer1000
Pioneer1000
16
58
Bunnell
This is my first post ever on a forum like this so hope I do it right lol been reading for years.
Just bought a new pioneer 1000 haven't ridin it yet but I worked on it this last weekend I'm a truck driver so not much time but their will be more to come
What I've done so far custom snorkel looks like roll cage
Also mods the stock exhaust made new tip for it and driled 3 holes in the first baffle and it sounds great!!!!
FastRedneck
FastRedneck
32
62
Cave City, AR
Looks like we've got another welder with a bit of skill....that TIG job on the tip looks great. That's pretty much the only thing I've never learned how to do. I want to so bad, just don't have anyone in my shop who does it or any equipment. But I can weld like a mofo with the MIG and arc. Welcome to the club, and that's a good looking color, I've got the same one and love it.
