Ugghhh...broken skid plates bolts. Help!!!
doolin64
doolin64
187
278
Small amount of buyers regret. Everything on this bike seems to be more of a project than expected. But I'm in it now and I'm going to correct the previous owners sins. I'm going to "Make this Pioneer Great Again!" Haha
Tonight I was dropping the stock skids for cleaning and ease of servicing. During this time, 6 out of my 21 skid plate bolts gave up the ghost during removal. Truth be told 2 of them were from the previous owner.
Vise grips do not appear to be an option. There's just not enough to grab. I've had miserable luck with easy outs in the past.
Does anyone here have good method for removal? Something besides drilling out and retapping.
103b4c9486c5c4c6700f8122373397ec
09fcb924bd62900bc545d78e7820d7cd
Reactions: Biteme
Eltobgi
Eltobgi
4,599
15,186
North Dakota
Clean the area and spray down with penetrating oil tap around the areas with a hammer after it sits for a bit to break loose and try to turn outward by applying pressure against bolt directly while turning back and forth...then repeat if not successful. Good luck
doolin64
doolin64
187
278
I do not have a welder. I tried welding once with a 110 on my Suzuki Samurai. Bird $h!t welds come to mind. I gave up on welding lol
Mind giving me a low interest loan for $4k. I'll buy your bike!
HUCK
HUCK
1,047
2,315
ARIZONA
Use a sharp punch and a hammer . Knock a dent in the top and T A P it to the left after you have sprayed wd40 on and around it and let it set for a while . Dont get anxious or in a hurry just steady tap tap tap tap tap .....................................it will work .
Grandpa taught me .
doolin64
doolin64
187
278
The only problem I see is how small these darn bolts are. They're only M6. I would think it would be tough to weld up a nut. Now I'm thinking of drilling out and using Rivnuts.
Reactions: Biteme
34,174
@JCart can tell you all about using Rivnuts/Nutcerts for the skids.
sharp
sharp
3,757
14,955
Tennessee
You could try using a bolt extractor kit from Lowes or Home Depot. Just a thought.
Reactions: Biteme and scottn57
highpocks
36
29
prescott mi
like they say spray it down let it soak then you can drill it out with a left hand drill bit. if that dont work use nut incert.
Reactions: Biteme and sharp
doolin64
doolin64
187
278
Does anyone have a left hand drill bit set they recommend?
Reactions: Biteme
