Ugghhh...broken skid plates bolts. Help!!!
doolin64
doolin64
187
278
I'm going the Rivnut/Nutsert route. My first broken bolt, drilled out no problem. Applied some heat, and snapped my easy out. Bleep it...they're all getting drilled out for rivnuts.
doolin64
doolin64
187
278
Sure has...I almost threw the towel in on this bike. Time/weather is my biggest issue. Trying to come up with a project name for this bike. [HASHTAG]#shouldaboughtJTWs[/HASHTAG]
Bhahahaha... yep! I do the same thing though.. I try and buy a something less expensive and at a deal.. but end up working on the damn things. I usually end up getting more money in the projects than I should and would have been better off buying new. It's a lot of damn money but I decided this time around with the sxs's that I wasn't going to even mess with someone else's problems. Never mind there aren't many used pioneers out there.
locoboilerguy
locoboilerguy
156
347
Western Colorado
You may know this already but McMaster-Carr is a great place for stuff like this. They have rivnuts in stainless and you can get stainless fasteners from them and maybe hold off the corrosion issue. I have been dealing with them for 40 years and if they don't carry it you don't need it. All the best.
Oh and by the way... two different people were eyeballing my 500 HARD and asking about price when
I dropped it off and picked up the 1000.. I think the manager was hoping to swap his out for it too! Lol..
Sweet!
Reactions: Biteme
Swampmonkey
Swampmonkey
142
133
Al
Anyone know the OEM part number for the skid plate bolts and washers?
Reactions: Biteme
crewcabrob
crewcabrob
1,029
4,038
Omaha
I had to do the above... had one that was broken off from day one. Tried to grab it with vice grips, no workie. Tried to drill it out and use an extractor, the extractor broke off. Finally pounded the weld nut off the other end and ran a bolt and nut through it.
JCart
JCart
897
2,024
Kamloops, BC Canada.
As a preventative measure, I made and installed a UHMW skid plate. Used the stock one as a pattern, the new one is almost 10mm thick enabling me to counter sink the Honda washers to flush. Much much more robust than stock and not mashed a bolt or washer since. UHMW is pretty easy to work with basic wood working hand tools, e.g., skill saw, jig saw, hole saw etc.
53C332B1 DA64 4D00 8FE8 29180DFB7D39
Tom_C
Tom_C
141
446
Virginia, USA
Check Bike Bandit or Partzilla, they should have a expanded view of the hardware. I just purchased M6 bolts with large flat washers to replace a few of mine.
As for the original question, I tried to get a broken bolt out and broke off my easy out, so when I get back to it I will drill a new hole beside it and use a self tapper screw.
Reactions: Smitty335 and HUCK
ODAMO
ODAMO
1,177
3,206
Ohio
Bike bandit went belly up
  • Sad
Reactions: Smitty335 and Tom_C
