“Clutch’s Basket” build
322,690
Lots of figuring out last two days. Get everything in and easy to use. Not too mention cheap!
Maximizing cabinet and counter space as well as figuring out what we have to use has been a b****. We know what we need in the woods but getting it all in...
Basic layout of the counter is laid out,sink is directly in front of the window as Ang likes it with room to move around for anything needed.
B55FDB2A 04A0 4B92 B352 7032020D0A1D
C1F71059 423D 4018 9E39 882BBE607AC2
E
elkguide
3,377
7,964
Vermont
Basic layout of the counter is laid out,sink is directly in front of the window as Ang likes it with room to move around for anything needed. View attachment 80106View attachment 80107
Is that going to be enough room for you to do the dishes comfortably @CumminsPusher?
208,726
Is that an under mount sink, SWANKY!
208,726
Uu Huh, fibber!
Use real silicone, take some masking tape, mask off how wide one joint will be both sides, take a bar of soap that is that width, wet it and press until it touches both pieces of tape, leave for 24 hours, pull tape and you have a factory looking caulk line. Don't try to clean up wet silicone!
322,690
Bad ass idea with the soap. I do tape seams, for me that comes from my automotive side.
449F1B0E FD53 40E0 BCF4 1362F8052E6E
Reactions: Chooglin and BWAF
208,726
I’m building a 30 yo boxvan...do I really seem like a fancy guy?
YEP!
Press the edge of the soap bar firmly against the tape! I saw your caulk job on your roof! HA!
322,690
YEP!
Oh on the roof lmao! Ya it was getting late and I could care less up there. It’s sealed! Double actually with butyl as well. If someone crawls up there to question things I’ll Sparta kick thier ass off.
322,690
Learned that from a professional corker about 30 years ago, wonder what I've forgot?
You’ve probably forgot more then many ever knew
Reactions: BWAF
322,690
Hope you didn't lose some aro dynamics with that caulk job, HA!
This rig is like throwing a brick into the wind, don’t think a little dirt that brick will matter.
Reactions: BWAF and Smitty335
lee
lee
Village Idiot
2,387
13,522
Springfield Ohio
Another way to skin a cat.
Add a line of silicon caulk.
Spray the area with water, from a spritz bottle like Windex comes in.
Use a cardbord toilet paper roll to scrape off the excess - it collects in the tube and the water keeps the caulk from sticking to unwanted areas.
Rotating the tube as you scrape is effective to prevent too much build-up.
322,690
Picked out the Knottiest (I know JTW will love this) wood I could find for countertop. Didn’t have the cash for actual counter top.
My daughter stained it last night.
327AA74F 1355 44DB 8FCA CE8BC1B1E9C6
C797513A B6CC 4A17 986B 236F425AC185
214C174D 753F 4C1C 9016 A3BF9FAA8F9D
Then brought down to my shop and sanded about 90 percent off and re stained for depth. Then went for some added flair. Went a tinted burgundy top coat with red pearl added. 5 costs then need to sand and repeat twice more. Should look pretty kick ass when done
88FD9F76 D775 48E4 BF49 A158038FEEB0
