P500 2016 Pioneer 500 Limp Mode
O
oakescharles
35
56
Yeah...I bought it from the 3rd owner. It had some issues. Thanks @906UP
42,130
I'd like to see a wiring diagram and see what goes where. If it is a newer ecm, you might be able to jumper the wires for the seatbelt input.
42,130
Looks like there are 3 diagrams, only 2 of which have the seatbelt switch. A15 is the pin for the switch, and it is unused on older models.
906UP
906UP
13,205
123,430
da Yoop
Good idea, there's more changes than just a seatbelt safety thing though.... 2017 had different gears in the final drive on the transmission so the speed sensor signal is a different number of counts per rev and '17 & up had the "auto shift" option.
42,130
Yes. 2017 actually has its own diagram, and then 18 and up has another (the manual I am looking at only goes to 19).
O
oakescharles
35
56
So if I ground out A-15 that should signal that the seat belt is engaged?
O
oakescharles
35
56
Which one is a-15?
A7B95BAF 0E24 4EC1 9E9B D2299FBF2E96
Reactions: DG Rider
42,130
The 15th one ( :) ). There might be tiny numbers cast into the connector. I can't access the manual right now. Your machine probably doesn't have a wire in the connector for it, so you'll have to get creative and get something on the ecu pin. Be gentle.
42,130
hahahaha...If this resolves the issue, I am going to set it to a toggle switch to keep my kids from going to fast.
Looking back through, it looks like you've already determined you have a 2017 ecm? Why not just get the right ecm?
Like I said, 2017 has a different wiring diagram from all the rest, so who knows what else works or doesn't?
O
oakescharles
35
56
I don't like to spend money unless it's necessary. If it doesn't work, I will buy a new one. If I fry it, I will buy a new one. If it works, I can spend $200 on something else.
Reactions: DG Rider
42,130
Wish I could figure out a way to post pages from the FSM.
