Glad to here you like those. I thought about trying one but went with the cheaper version that I bought through here. It and the fan do a great job but I have wondered how the back seat footwell protector workedThe heat issues with theses 20k plus machines is JUST BS plain and simple....
I know there are people on here selling heat shield, with that being said I went with the DEI Heat shield its a 4 piece system two pieces under the seat and also two pieces for the passenger rear foot well bought from Rocky Mountain.
It takes a few minutes to remove the seat and seat back and all the plastic, but after that not to bad I had to in large a couple holes on the heat shield but everything else is laser cut to fit with all the holes already in the shield.
Best mod thus far had stopped 99% of the heat, Must have mod for theses machines.
Not sure the material DEI uses but super heavy duty...
DEI Heat Shield Kit | UTV | Rocky Mountain ATV/MC
I only bought the shields, No fans, The sheilds work awesome cut the heat 99%Glad to here you like those. I thought about trying one but went with the cheaper version that I bought through here. It and the fan do a great job but I have wondered how the back seat footwell protector worked
How does it work for the rear passenger foot well? To date I have had no one ride in my back seats so I only know what I read about for the heat back thereI only bought the shields, No fans, The sheilds work awesome cut the heat 99%
What year and what model you have, My new LE all ready had some heat shielding stuck on the rear foot wells from factory so the DEI kit went over the factory stuff and covered a lot more area and the seats are thicker on the 2017 models also I already have Full Skids came from factory on the LE models.That is what we used and it cut the heat by 80%
Still need to do the fan, Josh at waiting on the Ricochet skid plat to arrive and do both at the same time and the SS brake lines from Jak
I wondering if some of theses things Honda did on the 2017 is helping to cut down the heat issues.2016 1000-5
Do you have the factory heat shielding on the rear passenger foot wells ?
So I wanted to Follow Up with everyone on this.I have decided to just run a Marine Grade Check Value on the overflow drain line for now, My thoughts are the rad get hot pushes fluid into the tank, rad cools down and creates vacuum sucks fluid back out of over flow back into rad.
The overflow bottle has plenty of extra space plus the tube for expansion so I will see how this works out, At least no way water is going to get sucked into overflow bottle with warm fluid and cold water witch creates a vacuum also and the River water etc gets sucked into the bottle.
Amazon.com: INHDBOX 8mm 5/16" Fuel Non-Return One Way Check Valve Petrol Diesel Marine Aluminum Alloy: Automotive
If someone else has any thought feel free to chime in....
View attachment 49739 View attachment 49740
Welcome from NW Arkansas, come on down!I just picked this up today for the wife's Birthday, actually she got it a few days early.
Ordered it with the Warn 4500 # Winch
Hard Roof
Rubber Bed mate
Honda Tilt out wind shield
Plan to add second battery and Light Bar, Radio, switches. etc.
Have tailgate cables on the way.
Also ordered one of the Honda 1000 V2 Rack that Brick City Fab sells.
The warning plate is different then the 2016 and there's not a lot of room under the hood.
Not sure how fast or slow this build is going to go..
View attachment 45425 View attachment 45426 View attachment 45427 View attachment 45428
Thanks !!! I have a few more things I want to add.Very nice looking ride.
