P1000 2017 Radiator Air Deflector
Plongson
Plongson
271
1,027
Southern Utah
What year is your rig?
Sorry, I should have mentioned our PK5 is a 2016, built 10/16 according to the ID sticker.
As for comments that my participation in this thread is "the problem", I'm baffled at your point of view, but to each is own.
These are the facts as I SEE THEM.
1.) Big corporations, including Honda are NOT OUR FRIENDS. They are here to take your money and give you something in return. The perceived value of both are subjective to the provider of each.
2.) Some have stated they believe there was little field testing of the PK5. I think there was EXTENSIVE testing and the PK5 is right where they wanted it when it was initially released...heat, gearing, clutches etc. It was a calculated corporate gamble based on profit dollars vs owner backlash and warranty repairs. This does allow Honda to make significant model year updates. Honda could care less if you're HOT...
3.) Perhaps you misunderstood my point. I never said the diverter mentioned was not a good or effective addition...quite the contrary, and I hope Honda includes the diverter in the BIG HEAT FIX we are all patiently waiting for...which I might add has been dragging on for months.
I could go on but I'll assume you get my point of view...and brand loyalty is essentially ignorance in the world we live in today. Big business is happy taking your money but they sure put on the brakes when you need something back from them. Witness the fact how happy we are when defective clutches are replaced under warranty...regardless of how many hoops one had to jump through to get it done.
One last thought to ponder is the old saying..."Follow the money" Just say'n...
115,790
If they put it on everybody up north would b**** about how cold the cab was..LOL
I thought about that too! That's ok, I'm snowmobiling then anyway.lol
Reactions: DRAGFOOT
GPR1500SC
GPR1500SC
861
2,426
North East MO
  2. Talon X LV
Did u order it today?
I did and it took it but a 1/2 hr later got the email saying out of stock/ not available that's when I started looking around. Most showed it but when I called to confirm they had it they gave me the same answer.
I only now am getting around to updating the post, my order showed up last Friday with everything included.
Reactions: Remington
Good points. Don't run off.
115,790
They must have gotten some in. The rubber air guide arrived today! Just need to find some time to install it.
115,790
Same here got mine today. Hopefully install tomorrow
Looks like I'm gonna have to drill a hole's. Mine did not have them up there. Story of my life LOL. That's OK it'll get done anyway glad to see yours came in too
Plongson
Plongson
271
1,027
Southern Utah
I ordered the air deflector and rubber from Rocky Mountain along with the push pins...on back order. I have the holes in the cross member from the factory, what makes it a PITA to install? Does it not slide up into position or do you still have to tear the machine apart?
DFWJ
DFWJ
10
12
DFW
Just ordered these parts today from my local Honda store.
The rubber piece was available, but the plastic shield was backordered.
They also said the clips to attach the rubber to the plastic piece were discontinued
115,790
I didn't get the plastic clips, I found some black machine screws to connect the rubber to the plastic I don't think it's that important how or what you use to fasten the rubber to the plastic
Reactions: Hawk53
208,731
I think Honda is light years ahead of the US Government and thats not saying much!
ToddACimer
ToddACimer
Pioneer 1005-2
3,746
15,867
Oshkosh, Wi
The area to get your hands in has 1-2" clearance and the push pins are almost an inch long before you get them in the holes and seated. Just a very tight install. I guarantee it's done before the front under hood panel is installed during initial assembly
elkaholic
elkaholic
Illegitimi non carborundum
2,097
8,606
Ridgeway, SC
Got mine installed this morning. I was lucky as the holes were already there. Still a pain in the a** to install. Going to NM next week and hope it works.....
Isn't it though. I was making a sailor blush as I installed mine
Reactions: joeymt33
elkaholic
elkaholic
2,097
8,606
Ridgeway, SC
After 30 minutes of trying, I installed the passenger side push pin backwards.
Also had the same issue with pins for the rubber, take the plastic piece with you to Lowe's. I found some "Ford" plastic body variable depth pins that worked perfectly
Reactions: JTW and Remington
