P1000 2017 Radiator Air Deflector
115,790
Isn't it though. I was making a sailor blush as I installed mine
I'm in the process myself. Had to come inside and work out On my bowflex to forget about it Lol. What methods or method did you use to drill the holes? Mine doesn't have the holes:mad:
Reactions: dotman1
elkaholic
elkaholic
Illegitimi non carborundum
2,097
8,606
Ridgeway, SC
I got lucky and mine had holes. I've added so much electrical crap under the hood, I would not have installed it if I did not have the holes.
I can say that from looking at things, unless you remove the radiator, you probably need a right angle drill to drill the holes
Reactions: Remington
115,790
That's what I was thinking about the right angle drill. I got so much electrical that I'd have to remove it to even get the front top off. I think walking away this evening will give me some time to re think how to do this.
Reactions: Hawk53
elkaholic
elkaholic
2,097
8,606
Ridgeway, SC
You might try this instead https://amazon.com/3M-03609-Scotch-Mount-Molding-Tape/dp/B000BO913C/?tag=sxsweb24-20
I have used it before and it really works. Or use some 3M 5200 marine sealer and clamp it in place until it dries. In either case, you will likely destroy the plastic piece if you ever remove it (a ceertainty with the 5200)
115,790
That's a hell of an Idea. It kinda crossed my mind but flew on by like a F18 in a fire fight. Lol. I might have to look into that. From the post it's seems to work so I don't plan on taking it off. Too hard to put on anyway lol
elkaholic
elkaholic
2,097
8,606
Ridgeway, SC
I got my tape at AutoZone. It is the second strongest level and it works good and is easy.
The 5200 is messy but is stronger
115,790
Do you think the tape will do it? Or should I get both just in case?
ToddACimer
ToddACimer
Pioneer 1005-2
3,746
15,867
Oshkosh, Wi
After 30 minutes of trying, I installed the passenger side push pin backwards.
Also had the same issue with pins for the rubber, take the plastic piece with you to Lowe's. I found some "Ford" plastic body variable depth pins that worked perfectly
I drilled the holes in the plastic for the rubber out to 6mm and installed the regular push pins
208,731
With all the heat coming from the seat, I never noticed heat from the dash.
ToddACimer
ToddACimer
Pioneer 1005-2
3,746
15,867
Oshkosh, Wi
A die grinder with a pointed tip carbide Burr would probably work instead of a 90° drill as well. You just need to be careful to hold it in place for a round hole
ToddACimer
ToddACimer
Pioneer 1005-2
3,746
15,867
Oshkosh, Wi
The dash was pretty warm around the shifters and the air flow over your arms while driving is coming from the shifter holes. Removing the hot air flow from the shift holes definitely reduces the overall warm air inside the cab. I have not tried my windshield again since adding the deflector but it might be worth another try
115,790
Thanks I thought of that, because of the small hole in my die grinder, I'd have to grind down my step bit quite a ways to make it fit. Still might try it anyway.
ToddACimer
ToddACimer
Pioneer 1005-2
3,746
15,867
Oshkosh, Wi
Thanks I thought of that, because of the small hole in my die grinder, I'd have to grid down my step bit quite a ways to make it fit. Still might try it anyway.
I was thinking something more like this.
Forney 60126 Tungsten Carbide Burr with 1/4-Inch Shank, Tree Pointed, 1/4-Inch https://www.amazon.com/dp/B003X432C8/?tag=sxsweb24-20
Since I couldn't really get a center punch down there I started my holes with a similar bit before switching to the unibit
115,790
GlockMeister
GlockMeister
The Bearded Wonder
7,606
35,593
Greenville, Mo
Theres only one bad thing about all these heat fixes....winter is coming!
Dont know about you but i thoroughly enjoy the heat in the winter. All of my heat fixes are easily reversible. Something to consider before making it permanent . Just my 2 cents.
elkaholic
elkaholic
2,097
8,606
Ridgeway, SC
Cannot use both. I think the tape will do. Degrease both surfaces first.
115,790
Good point. I don't use it too much in the winter, but the amount that I do I just shut down the bilge fan and I usually get enough heat to satisfy. Just me.
ToddACimer
ToddACimer
Pioneer 1005-2
3,746
15,867
Oshkosh, Wi
It's just 3 push pins of it's installed like the factory one. I doubt you would notice the heat with gloves and a jacket on either
208,731
Warranty renewal is almost here, I'm hesitant to spend any more money with Honda, when they haven't fixed current issues, HEAT! Honda Corp. is a piece of SH**
Reactions: Montecresto
