BOX1
P500 2021 Pioneer 500?
hondabob
1,155
4,492
Prescott Valley, AZ
There should be a Pioneer 500E electric model. Honda had pictures of it a few years ago. I want a Pioneer 520 with all the good stuff that is on the Foreman Rubicon. We have several 50 inch trails here and a couple need a locker on the switch backs plus some really tough rock crawling canyons.
hondabob
1,155
4,492
Prescott Valley, AZ
Slide4
Honda power 620x647
Slide2
Slide3
Reactions: Mudder and Mudwing
hondabob
1,155
4,492
Prescott Valley, AZ
1border4manu
1border4manu
2,133
14,386
Zephyrhills, Florida
Maybe Honda will make a 50 inch Talon for 2021 with the 520 motor. Wishful thinking.
The Green Goat
The Green Goat
1,705
12,042
Jerryg
Jerryg
9,963
81,894
NEPA
It would be nice if they pre-install the winch mount.
I was looking at the 16 pages worth of installation instructions and was thinking, that's a days worth of work.
G
gtistiffler
You can do a 520 big bore if you wanna open up your engine
Reactions: J80
906UP
906UP
12,816
119,044
The 906
That's my plan for the Donkey this winter, it's starting to use a little oil, not enough to warrant a top end rebuild but that's the excuse I'm using :cool:
Going to use the OEM 520 Foreman cyl, piston, rings.
906UP
906UP
12,816
119,044
The 906
Better do some checking first,Crank Shaft part #'s are not the same.
Not sure what model you were checking but the 21 Foreman 520 FM1 (manual shift) has the same crank, the stroke is the same, only the bore increased in size. The cyl "should" be a bolt on, at worst the cases may require some finesse to accommodate the larger cyl liner.
BOX2
box3
