Is it true the torque specs are wrong in the manual ..
I know this has or must have come up and read about before,but it was to late for me until a knew i over torque the 3 bolts for the oil filter cover on the 2nd oil change, so i left it alone till it was time to do the 3rd oil change...
Now fast forward today this is what it looks like when you over torque a bolt....Can you tell the difference.
So again was in a pickle and needed some bolts so i bought these thinking Honda would be out of stock .90 cents.Hex bolts probably just as good...
So here's the good parts Decided to give Honda a call a low a behold they had 7 in stock my lucky day so i figure may as well put the right OEM bolts as the 500 is still under warranty and didn't want them to see the aftermarket hex bolts...
Long story short i have a buddy ya that right buddy of mine works in the Honda powersport parts Dept and showed him the twisted bolts he said" Wow never seen that before" I'm like that under warranty right He said No but he was kind of enough to give me them for free....10 bucks is 10 bucks in my pockets,,,He said Here, now get TF out of here and have a great weekend...lol.
Part #....
So bottom line if u accidentally over torque your 3 bolts check them before you install them or else you might end up snapping the head in the block and then you'll be in a pickle...
That's my Shop Talk Later...
Part #....
