P1000m5 7.5 wide enclosed trailer?
sjacobson48
sjacobson48
24
87
Is anyone on here currently using a 7.5 ft wide enclosed trailer for their P1000-5 ?
My trailer guy tells me he sells a lot of 7.5 ft wide trailers to SxS folks because they allow better vision behind you when towing versus a 8.5 ft wide version, yet still plenty of room inside for a SxS.
That sounds great.... but while I believe that to be true relating to a Polaris where the wheels are outside the main body and you can climb over if necessary....the P1000 is more like a box on wheels and I'm not sure you'd have the necessary space to get out?
He offered to let me check it out if I take my machine there... but it's a 2 hour drive and I was hoping to get input here before doing that?
Reactions: ChadD
bumperm
bumperm
1,899
6,778
Gardnerville, NV
7.5 feet, I assume is the trailer outside measurement, how much width inside? Measure that out on the ground to see if it's workable for you. Will you need to access the front of sxs, when it's in the trailer, to tie it down? Will the trailer have a side door, and if so, will it be located you can open the sxs driver door "into" that side door opening when you are clambering in and out? Or will you have to crawl over the front seat and out the back etc?
Jankyeye
Jankyeye
827
4,004
Tampa, Fl.
My local trailer place hasn't had a 7.5' trailer on the lot in a couple years. I cant see an extra 2.5" on either side being a big improvement for the pioneer.
272,137
Here ya go, I can verify it will fit Two P1K's & 1 P500 all at once or 1P1K / Talon 4X and living quarters.
115,707
That sounds great.... but while I believe that to be true relating to a FIRE TRAP where the wheels are outside the main body and you can climb over if necessary....the P1000 is more like a box on wheels and I'm not sure you'd have the necessary space to get out?
Fixed it for ya!
Yes you will fit!
sjacobson48
sjacobson48
24
87
Thanks Jackal..... But I can't pull that with my truck😂
Reactions: ChadD and Remington
Scoop
Scoop
5,140
20,318
  3. Talon R LV
You just need a 7' wide with an escape hatch on the driver's side:
1663181639369
906UP
906UP
14,269
135,336
da Yoop
I use a 7' wide (outside) x 29' for my Talon X & P5, it's fkn tight but can be done. It's what I had, bought it for snowmobiles but they're gone. No sense in selling it to buy a bigger one in this market.
