97 Power stroke F350 build.
What Color to paint the Truck?
  • Factory Hunter Green
    Votes: 11 37.9%
  • White
    Votes: 12 41.4%
  • Other
    Votes: 6 20.7%
  • Total voters
    29
knuckledeep
knuckledeep
my trailer queen is trashy
1,052
3,470
Eustis florida
Add acts as a cleaner and lubrication for the injectors the non silver diesel doesn't have hardly any lubrication
Reactions: moparornocar
Gator
Gator
The Most Unknown Member
2,489
10,470
Louisiana
I've heard of using ATF in the filter bowl. ATF has detergents.
I drained the filter bowl on mine and filled it with "Sea Foam". This was recommended by the only guy I've met with the ford logo tatoo'd on his chest. It worked.
Also, The injectors will struggle if the voltage drops below 12 volts. Make sure you have good batteries.
moparornocar
moparornocar
RIP....Rocmar...
4,606
12,493
Augusta, Wisconsin
Batteries are both brand new. I may try the injector trick. I was wondering if sea foam would work. I love it in my gas motors. I'll give the ATF a try and see how that goes. As soon as I figure out where the fuel bowl is!
Reactions: Tramguage1
rocmar
rocmar
4,741
5,776
4 CORNERS
Mopar is my favorite. In all fairness, I've owned 114 cars since my 16 the birthday. Just about every make except Mercedes, jaguar and the Italians.
Tell me...you had a
Frickin two tone pinto
.....lmfao
Reactions: Plumber32
Jamesgang
Jamesgang
148
297
Kitzmiller, Maryland
Top dead center of motor. think of where the carb. would be on gas motor. There is a leaver to drain it also next to it. It has a water separator system on it I think. That is what the leaver does I believe. I owned two of these trucks back in the day. 1995 and 1997 models.
moparornocar
moparornocar
RIP....Rocmar...
4,606
12,493
Augusta, Wisconsin
Gotcha. I'll check that out when I get home.
moparornocar
moparornocar
RIP....Rocmar...
4,606
12,493
Augusta, Wisconsin
Picked these up today. 50 bucks off Craigslist. Gotta figure out how I'm going to mount them next. Can't wait to hear them installed!
IMG 20170415 174558684 HDR IMG 20170415 174604514 HDR
Delton
Delton
Honda Fanboy
9,967
31,488
Middle TN
Doesn't ford use Holset turbos?
Tflynn
Tflynn
Not a liberal
2,501
3,833
Northern California
I don't want to try to tell you how to do your build, but my only suggestion for that particular model year truck is a full tranny build. I had a friend that had one and towed a lot and the only issues that ever arose were in the transmission. My friends truck was an automatic though, what's yours Mopar? Sorry if you already said I must have missed it.
moparornocar
moparornocar
RIP....Rocmar...
4,606
12,493
Augusta, Wisconsin
Mine is an auto. If the e40d in it now s***s the bed I'll be putting a manual trans in it.
Reactions: Tflynn
Tflynn
Tflynn
Not a liberal
2,501
3,833
Northern California
Probably the smart thing to do. A properly built auto will run anywhere from $3-5000. I'm sure you could swap in a manual for less than that. Plus a manual is cooler!
moparornocar
moparornocar
RIP....Rocmar...
4,606
12,493
Augusta, Wisconsin
Agreed! I could buy an entire 5 speed donor truck for a grand or so. Couple hundred bucks for a clutch and youre off to the races.
Reactions: Tflynn
moparornocar
moparornocar
RIP....Rocmar...
4,606
12,493
Augusta, Wisconsin
Diagnosis is a broken rocker arm and the trans is shot. She's at the diesel shop now getting the motor all hunky dory then home to pull the trans. Found a shop that will rebuild it for 1500 bucks with a new converter and all new guts. I'll be posting pics of that clusterfk. Anybody wanna come help pull a trans?!
Tflynn
Tflynn
Not a liberal
2,501
3,833
Northern California
I'd do it but by the time I got there you'd be done with the entire build!
