P700 Accesory wiring - what wire to get ign
P
Pokeman
NY
I am in the midst of adding a Winch and stereo to a '16 700-4. I have already wired in a race radio coms and a GPS. The Warn 4500-s Pro requires a feed that is only hot when the ignition is on.
I've got the fuse block out, relay block out, and the ignition cylinder all out under the hood. So I already failed to guess right and I cannot find a decent wiring diagram. What color wire coming out of the ignition will only be hot when the key is turned?
Or same question for the relay block.
I need to find what wire to tie into.
Reactions: Neohio
Neohio
Neohio
Beast of the East
17,719
85,397
Painesville Ohio
The winch does not require a keyed hot feed. Using a keyed feed only allows the winch to be used with the ignition on.
I am just downloading some Honda instructions, the winch and power panel. One of these should give the location for the proper wire.
Edit: According to the winch instructions, it is getting the keyed power feed from the fan connector. I do not own a 700, nor have I spent too much time under the hood of one.
@swsebek @Mudwing
P
Pokeman
NY
I guess I can add a switch. but I'll look at the fan connector.
swsebek
swsebek
2,854
5,835
pa
The most used keyed switch for the winch. Is on the back of the accessory plug. It's the white and black wire.I believe it has not changed over the years. But you will see it under the hood and it runs to a green plug that is supported in the center steel supports for the dash and behind shifters.and I mean accessory plug under dash in the center. Looks like a cigarette lighter thingy:D
