Talon Accessory panel and winch wiring questions.
Jefferson87
Jefferson87
258
275
Northern California
The switch plate is the same for 2 or 4 seat models, there is a separate harness also needed to reach the back of the 4 seater that they forgot to mention in the updated instructions.
To be fair they designed it with their accessories in mind, and I believe each individual accessory is fuse. I think it's a better design in the long run, since you aren't actually stuck with their accessories like the P1K,
Someone at Honda needs their ass kick for the accessory instructions they've been putting out, its abysmal at best.
So I have to spend another $50 for a few wires? :rolleyes:
Having 5 different accessories with fuses mounted to the harness is dumb imo.
I don't see why they couldn't have done it like Ford did their upfitter switches. The switch panel is all pre-wired to the fuse block. So when you add a new accessory, you just tie into the fuse block. No need to tear the dash apart each time. This is how I plan to do mine. I'll have maybe $150 into it, but that includes bulk wire and connectors, plus I'll have an actual fuse block.
Reactions: Kevinka1977
nitrotmann
nitrotmann
52
150
  1. 1000 6 Crew
I completely agree that yet they should have done factory up fitter switches like Ford. If you could list what you used to do the wiring for not getting the Honda bs expensive switch plate, that'd be great.
CMB
CMB
5,108
55,091
  2. Talon X LV
Anyone here care to help me out with a winch issue ?
CMB
CMB
5,108
55,091
  2. Talon X LV
just installed axon 45rc double checked all connections, and nothing works.
CMB
CMB
5,108
55,091
  2. Talon X LV
Im getting 12 volts at red wire (keyed power ) fuse good. red and black on winch 12 volts.
7,139
27,139
Ok I just downloaded a install manual.
Do you have the large black and red from the battery on the contactor? Not sure if the contactor is paint labeled.
7,139
27,139
Damn this should be a plug and play.
CMB
CMB
5,108
55,091
  2. Talon X LV
well thats what i thought
:oops:
7,139
27,139
Screenshot 20200202 172330 Adobe Acrobat
CMB
CMB
5,108
55,091
  2. Talon X LV
7,139
27,139
Is this what ya have?
7,139
27,139
Is there a loose small red wire? Where the key is in the photo.
CMB
CMB
5,108
55,091
  2. Talon X LV
yes
Ive went over every connection, checked voltages switch and remote.
CMB
CMB
5,108
55,091
  2. Talon X LV
its good 12 volts key on power. fuse good
CMB
CMB
5,108
55,091
  2. Talon X LV
the red and black cables under hood, where is the black one go too ? I know its a ground . I connected the red one to solenoid
7,139
27,139
I see it looks like the remote has to be plugged in to operate.
CMB
CMB
5,108
55,091
  2. Talon X LV
Yes. ive had both plugged it at same time, and tried both
7,139
27,139
You have a Pioneer or Talon? But both should have a black large factory wire with blue tape under the hood. Think all models except 16 pioneer
