P1000 Adding 2nd battery, isolator PDM, 6 switches
ShadowAero
ShadowAero
“Big Tasty”
107
207
Mount Dora, FL
I bought a 2nd battery, a PDM60, True UTV isolator, switch panel with 6 switches from ottraw and 2 battery 12 volt. Now i am not sure how to wire it all. Looking for anything to help.
Get you battery's mounted
Isolator installed
Pick a spot for the PDM60
2bbefadf0e428aaaf6ce0b89b44f73f3
B1b1b7b763baed9820c72e288195eaa4
Get all your accessories mounted.
Cut the switch plate hole out.
Pick the circuits on the PDM60, remembering that there are rules for each.
Use the amp draws for the accessories to plan how you're going to land them to the PDM.
Once you have all that in place, and have decided what the switches are going to do for you start running the wires from the accessories to the switch panel leaving an extra 18" or so to give you room to the land them to the switches.
PM me I've got pretty much that setup I'll be glad to help you anyway I can.
Reactions: utvmi
ShadowAero
ShadowAero
“Big Tasty”
107
207
Mount Dora, FL
Isolator installed
That's awesome. Pics look great. I have a question. Why do you have a bunch of relays? I thought the PDM60 replaced the need for relays.
I also have mounted dual fans under seat for heat control but did not wire them yet. Trying to figure out how to run the wires to under seat area. Want to make sure the wires aren't exposed underneath vehicle.
Do you use a laptop to connect to setup the programming for wire function? Like switched power, delay, etc?
How did you mount 2nd battery. Did you attach primary battery ground to 2nd battery and Primary ground to frame?
I am making a diagram to see if i am wiring it correctly.
ShadowAero
ShadowAero
“Big Tasty”
107
207
Mount Dora, FL
Here is what i came up with. But don't know how wires from PDM wire to the switches. Can you tell me if i have any of it wrong?
And thank you for your help.
Screen Shot 2017 06 15 at 111935 PM
Wiper requires a relay to park the blade, my light bar draws more than PDM can provide on a single circuit.
I used my winch contractor as a buss point, the cables coming up through the hole are from second battery under seat.
I took the skids off and ran the cables through AP wire loom, zip tied out of danger. I have UHMW skids too.
Yes laptop, my mac works way better than PC.
I connected battery to battery with 4ga cables, frame is not a good ground. Diagram looks good.
ShadowAero
ShadowAero
“Big Tasty”
107
207
Mount Dora, FL
I ended up finishing the project. It works great. The pics were taken at night. The switches are so bright at night i had to turn exposure way down. Thanks folks for the help!
1000 5 wiring IMG 4111 IMG 4108
