P1000 Any ever hook a fan up like this
EricG
EricG
177
162
North East PA
Just wondering if anyone ever hooked up a 12 volt car auto fan like this in the cab to cool you down. Redneck AC for those with windshields. Just curious how it worked if so.
817 2
I use a small fan in the summer. It’s just a clip on style though.
8906ddf946075474c227adace5d96a6c
Reactions: EricG
And it works decent for you? I was thinking about hanging one from the roll cage with a bracket. I have to wait and see though once I get my stereo installed if there is room to do it.
It pretty much just blows hot air but sometimes after working in the yard it’s better than having no breeze at all. I find my wife using it too so it must feel ok.
Even my boy likes it.
E09271af6cd22233708911a1936244dc
320,694
IMG 1957
We use this aimed down from the roof. Works well for defrost and helps a little during the hot months
nbomar
nbomar
4,416
17,854
Springdale, AR
I have this exact fan and used it the entire first summer. It helped for sure when we were slowly riding the farm checking cows and no air was blowing. Not sure it does much if you are above 10mph.
Reactions: EricG
EricG
EricG
177
162
North East PA
That's what I am looking to use it for, not checking cows lol , but slow riding tight wood trails is mostly what I do with the machine. Thanks for the info! I see they make marine grade ones that oscillate, but of course you are looking at $80 as opposed to $20. I'm gonna end up doing this one way or another. Thanks again.
nbomar
nbomar
4,416
17,854
Springdale, AR
I bought mine at Walmart for $15 or so... it’s held up well to some water, mud, and general trail abuse. Clipped it on the lower windshield aimed back at us and oscillating.
Reactions: EricG
320,694
Here's the pic. The fans swivel separately 180deg
so you can get cooling too. Added a little heater as well so it was slightly warmer air for defrost. Fan was 12$ And heater was 7$ if I remember right on EBay.
IMG 1959
EricG
EricG
177
162
North East PA
Thanks for that and just bolted to oem roof I assume? Backed up with a large washer or something to that affect? The heater just to help defrost or is there a noticeable difference in temp in cab? I was thinking about putting the blower under the seat like you guys have done and venting it to the cab.
Reactions: CumminsPusher
320,694
Ya simply bolted trough the roof. Figured I'd want it permanent I don't like things bouncing around. We have enclosed cab so it is warm anyways but heater it does help a little, mainly it's just warm air to help the windshield when cold and snowing. Works very well for that, worth the 7$
Did 3in fans into the cabin earlier this year on a thermostat and that brings in serious heat.
Reactions: EricG
EricG
EricG
177
162
North East PA
I'm envious of that cab you have, I wish I had the fabrication skills to duplicate something like that. It's one hell of a job you did. I wish someone sold hard uppers that attached to the doors rather than the soft sided cab. The price of hard doors is ridiculous for any of these sxs. Thanks for all the info!
320,694
thank you. I also wish Honda would do something better there but then they wouldn't sell any of the super expensive full doors lol.
Reactions: EricG
320,694
@CumminsPusher how has it held up. It might not be much but I (the wife.....) need a little moving at slow speeds. Rubber washer on top of roof to seal it?
Took the base off and ran a couple small bolts then reassembled, nothing crazy. Just a couple small screws down through the roof would probably work fine. I just put a little silicone around hole then dropped in bolt, a rubber washer would work fine.
