P1000 Auto start been done?
O
OleRed
142
275
So, had to ask the question. May sound a bit crazy but with this group, what doesn’t !? Anyone have it installed?
E
elkguide
3,377
7,963
Vermont
We're all anxiously waiting for your install and write up.
With pictures a diagrams we hope!!!!!)(
Reactions: Plumber32
66,820
You talking remote start?
13,422
65,848
Shouldn't be too hard.
If you need wiring help, tell me your model year and the system you'd like to install. I should be able to help you.
Reactions: sharp
Farmer
Farmer
2,850
16,380
Southern MO
I'd consider buying a cab for my 700 if it had remote start.
O
OleRed
142
275
I wouldn’t think it would be to hard— there are a lot of folks that have explained nearly every wire in the machine— people have a good brand?
13,422
65,848
Depends on what you want. I believe Viper was top of the line for a long time. But I have been out of that game a long time.
Do you want simple 1/8 or 1/4 mile range? Need remote feedback with alarm etc?
13,422
65,848
My biggest concern would be sealing your wire connections to keep the elements out. Much easier in a vehicle where all connections are done under dash where weather/mud/water is not a concern.
O
OleRed
142
275
I would just want one way 100 yards or so. Nothing too fancy just need to warm up from ice shack or inside the house
66,820
I've seen it on snowmobiles.
O
OleRed
142
275
Thanks Neo— Should be sometime between seasons coming up here and I will give it a go
13,422
65,848
I couldn't find a wiring diagram for the remote start, if you come across one, I'll tell you where to hook em up.
O
OleRed
142
275
Reading reviews it says they email it to you when you buy.
Reactions: Neohio
jwfirebird
jwfirebird
927
1,446
western ny
any of the dei brands are good, viper is one, like ten I think, I would solder and heat shrink every connection. only input I would question is the tach signal for reading when the engine starts to shut it off. some only work with certain cyl like they have jumper settings for 4 6 or 8 cyl, but some of the better ones will have auto read function that may work better
Reactions: OleRed
13,422
65,848
I think the viper monitored battery voltage to verify it was running. I don't recall 100% though.
O
OleRed
142
275
Do they commonly list the cyl options in specs on the auto start products? Trouble is, I can't get any real details on this thing until I order... says the bible of reviews on amazon
tjoreo
tjoreo
1,011
1,929
Southern Idaho
I've installed some of the Ready remotes (now DEI) on about 4 different vehicles and they seem to work very well. I was just looking but they seem to have changed there website so you can't look at vehicle specific wiring diagrams without a bar code of the product. The ones I've installed don't work off a tach signal, but rather run the starter for a few seconds then check voltage. They are pretty straight forward and I believe for the pioneer, they would be pretty easy to install. Unlocking doors and tooting the horn might be a little tricky though.
Reactions: jwfirebird
