P500 Beating a Dead Horse?
182,320
To disconnect or not to disconnect the anti sway bar?
This subject brought some heated debate and discussion to this forum in the past. Some saying it helped greatly, others saying there was no difference and others that just wouldn't do it because Honda must have had a reason for putting it on there. Doesn't come up too much anymore, but figured I would share my take on it now.
I was one of the guys that wouldn't do it regardless of what others were saying. Left it hooked up over a year and then it would come up again, kept meaning to try it. Finally unhooked it, zip tied it up and gave it a shot. Told the wife about it and she wasn't real happy with the idea, told her I'd hook it back up if it sucked. After unhooking it, I thought it felt soft just pushing down on the rear end sitting in the garage, so I cranked the shocks up one more notch.
That was in April, took the machine out for the first real ride today, she had forgotten all about it. Put it through its paces, 50" quad trails all day, tight, banked turns, off camber, whoops, through the woods and hitting the limiter. After an hour or so I asked her so what do you think? Had to remind her what I'd done and she said 'I thought it was riding smoother'. I went into it skeptical as well and it made a believer out of me.
The best I can describe the difference is that it used to feel really tight in the rear and choppy on bumps, like you were losing ground contact with the rear tires. You'd think that this would have gotten worse after I cranked the shocks higher, but it didn't. Smooth, never felt like it was chopping which meant better control. Didn't have horrible body roll either, took a couple of curves pretty fast just to get a feel for it.
FWIW, thought I'd share that with those that might still be on the fence. Easy to try and put back if you don't like it. Needless to say, I won't be hooking mine back up.
PS. Never would have done this if not for this forum. Thanks guys!
105,595
Where is the anti sway bar located on the P5?
Reactions: sharp and Jshell3
rocmar
rocmar
4,741
5,776
4 CORNERS
Wat I don't get..is wire tie...or zippy tie
..it up...remove...it..
Reviews..mostly say...way better..
...I used the word..."loose"..
let's all remove them...find a welder
to make something kool...out um all...
iowaguy
iowaguy
624
1,425
Eastern Iowa
I'll always remember the look on my wife's face after I had taken ours off, we were traveling a pretty good speed coming to a big bump and she braced herself like usual, we hit it and see gave me a look with a grin on her face, and said ,why didn't you take that thing off when you bought it.Needless to say mine is never going back on
rocmar
rocmar
4,741
5,776
4 CORNERS
Not recommended. ..if you carry a heavy load....fast on turns...
Sway bar ties both rear wheels together......mine feels way different..
without...now I'm 8" wider......
182,320
Zip tied was just to try it out. I had every intention on hooking it back up if I didn't feel it was beneficial, no placebo effect going on here. If I wouldn't have been able to tell any difference, I would've hooked it back up just to be safe. I honestly think this machine rides better and safer with it disconnected. Made an awesome machine even better, no BS!
iowaguy
iowaguy
624
1,425
Eastern Iowa
It is this thing on the back between the wheels WIN 20170514 211730
rocmar
rocmar
4,741
5,776
4 CORNERS
I agree....un hooked mine last summer...
went campin...left to get firewood...
empty of weight...ride was nice...loaded
wood..ride back.....not the same...just sayin
rocmar
rocmar
4,741
5,776
4 CORNERS
Most guys....haven't removed..alot of post sayin
...just left um tied up
chrisC
chrisC
138
259
Newfoundland, Canada
i just took one link off of one side .
Took a minute. would take only a minute to hook back up.
no zip ties
FuzzyGrub
FuzzyGrub
373
532
Rural NY
www.joefishin.com
I have been "chicken" to try it. My concern has been flat turns on dirt roads, and the sideways trails on steep hills. 90% of our riding is two people. At least this doesn't cost anything. :)
I'll take a look this evening.
