P1000 Bed tilt angle for maintenance
ODAMO
ODAMO
1,177
3,206
Has anyone modified their bed to tilt up higher for doing maintenance? It sure would be nice to have it go higher to get at it easier.
I mean just to check the air filter you practically have to stand on your head and spit nickels to do it
ODAMO
ODAMO
1,177
3,206
I now realize that those of you with the 5s can tilt your bed, and then open rear doors to have clear access.
Four screws will remove the bedside on the 3s . Just wish it was a lil easier
ODAMO
ODAMO
1,177
3,206
ED8F1AFB 9FD7 4F47 9343 460EE5EE0153
Removed the rubber bumpers on bed hinge and gained considerable working room.
Will put them back in for dump duty.
Jerryg
Jerryg
10,691
86,453
NEPA
My Yamaha X2 is the same way.
I Just recently changed the spark plugs.
It was easier to kneel on the front drivers seat and reach over the roll cage than to try and work under the bed.
Reactions: Lady01
ODAMO
ODAMO
1,177
3,206
There only in place to keep the bed from hitting the muffler guard.
Actually the gas cylinder tops out before the bed hits. I may even see if i can modify the mount and get even more angle. Its about 50° without bumpers.
Scoop
Scoop
4,239
15,884
  3. Talon R LV
I'm 6' 2" and have zero problem working under the tilted bed. Meh. 🤷‍♂️
Reactions: GovtMule
GovtMule
GovtMule
NTC’s SoA, Chief Sarcasm Officer-Self Appointed
12,087
117,167
Tennessee
I’m 6’5” and will report when I service mine next week. I suspect I will adapt and overcome.
Reactions: Scoop and Jerryg
