Ok guys I am new to the forum hope this is in the right spot. I have a p1k that has taken in water going though a shallow puddle if water at a high speed. So I drained the oil pulled plugs and started it up and had a knock so I took it in to Honda they didn't even touch it and said that Honda would not cover it and that it would be $7,000 to $10,000 to fix. So obviously I wasn't paying that so I took it home and started to pull it apart I found that the 1 rod is bent and the piston is just barley hitting the counter weight on the crank. I am going to replace both rods both pistons rings and head bolts and out it back together.
![IMG 20161029 143846949 HDR IMG 20161029 143846949 HDR](https://hondasxs.com/data/attachments/24/24896-0be4cdfd7d3f34c4a2a6a319df4fbec7.jpg)
![IMG 20161030 123758755 IMG 20161030 123758755](https://hondasxs.com/data/attachments/24/24891-218bc3e85c9113c983b7b4e072ea1f92.jpg)
![IMG 20161030 122218437 IMG 20161030 122218437](https://hondasxs.com/data/attachments/24/24893-584bd8d3236e2c87819390f96c1aa801.jpg)
![IMG 20161030 123806158 IMG 20161030 123806158](https://hondasxs.com/data/attachments/24/24894-8729b49c984da37462e8ae2915647feb.jpg)
![IMG 20161030 122204600 IMG 20161030 122204600](https://hondasxs.com/data/attachments/24/24895-a3b5f1b89df94dda38e57d8f9413090e.jpg)
