P1000 Bent connecting rod
Delton
Delton
Honda Fanboy
9,967
31,488
Middle TN
I thought about you the other day. With no news being reported, I figured something was on backorder.
Reactions: CumminsPusher
Cwilkins
20
47
Florida
IMG 20161217 094113968
IMG 20161217 112050440
IMG 20161217 112111415
IMG 20161217 094113968 IMG 20161217 112050440 IMG 20161217 112111415 IMG 20161217 094323362 IMG 20161217 094338558 IMG 20161217 120333475
Cwilkins
20
47
Florida
Got my machine back together finally. Word of advice order parts as soon as possible they will take awhile to get to you. 2nd you will definitely need a service manual. Study the manual before taking apart. Pay attention when timing the cam the book gets a little confusing.
P
powertech
14
14
East Ky
Thank you for the pics and advise. I have the exact same issue as yours and was hoping to get the oil pan off in the chassis.
Cwilkins
20
47
Florida
Drop the skid plate and you will be able to drop oil pan and shine a light and see how bad your rod is. Then turn engine over so that your counter weight rolls down to the bottom mine had 2 little shiny spots where the piston was hitting it but not bad enough to feel.
1BadDart
1BadDart
1,453
13,478
W. KY
Glad you got it back together. Are there any aftermarket cams for these engines? How do the ports look on the heads?
GPR1500SC
GPR1500SC
861
2,426
North East MO
  2. Talon X LV
The head looks pretty good for port size and air flow, if had mine off I would take the valves out and clean up the casting imperfection and polish it but didn't think it look like it was worth the effort to take the head off with out a reason.
I was still wondering about the African Twin cam?
Cwilkins
20
47
Florida
IMG 20170107 095713751
Reactions: powertech
P
powertech
14
14
East Ky
Thanks for the specs. I really do appreciate the help.
Craighonda
Gore,OKLAHOMA
Ok guys I am new to the forum hope this is in the right spot. I have a p1k that has taken in water going though a shallow puddle if water at a high speed. So I drained the oil pulled plugs and started it up and had a knock so I took it in to Honda they didn't even touch it and said that Honda would not cover it and that it would be $7,000 to $10,000 to fix. So obviously I wasn't paying that so I took it home and started to pull it apart I found that the 1 rod is bent and the piston is just barley hitting the counter weight on the crank. I am going to replace both rods both pistons rings and head bolts and out it back together.
View attachment 25357 View attachment 25359 View attachment 25360 View attachment 25361 View attachment 25362
Did you get get it fixed?
Reactions: Milkbone
Delton
Delton
Honda Fanboy
9,967
31,488
Middle TN
Saw a guy not long ago that swamped his. Ran it without checking the rod after changing fluids and the rod broke and went through the block. So $150 fix turned into over $1000.
Buddy of mine has a cbr1100 Blackbird that spit a Falicon rod out at Huntsville. We never did find it. Somewhere in the weeds alongside return road is my guess. Probably still there lmao
Mario17623
11
Dallas
Did you have to replace block?
Reactions: BWAF
