P500 Best Full Windshield?
Caper
Caper
7,801
11,030
Halifax Nova Scotia
I use NUVOS, it's made for polycarbonate, Harley uses it on their windshields. Leaves it like new.
Caper
Reactions: 100Acre
Mudder
Mudder
NTC/TAP Transition Member
11,874
90,510
@100Acre , let us know what Honda does about the cracks. Tell them they have many customers watching for them to replace it free of any charges.
Caper
Caper
7,801
11,030
Halifax Nova Scotia
Thanks Mudder After three calls, they took it to mediation and they would only go good for half the price. Better than nothing, like they said the first two times. Honda's a big company, so getting anything is good, I guess. And they let me keep the one with the cracks. so I drilled the end of the cracks and that SHOULD stop the cracks. So when that one does finally crack across, I have a new one.
One thing I was going to post is does anyone know how far you can get to a tank of gas. I've never really checked. Reason I'm asking ,I might be going on a couple of long runs, around Cape Breton. It will be a good test for the drilled cracks, haha.
Thanks again Mudder.
Caper
106,259
Mine had scratches, no cracks.RMATV gave me $100 gift card
Mudder
Mudder
11,874
90,510
@Caper , here is a thread that may help on fuel mileage, like others said, I get about 25 miles, mostly 2nd and 3rd gear less than 15 mph on trails. P500 - 2015 P500 MPG Data Point #3 PS, guess I got you and 100acre mixed up on windshield comments, hopefully you got a complete new windshield and have an extra set of quick connect mounts, they are nice.
Reactions: 100Acre
106,259
@ caper and @acre are close enough to confuse the two.
32lakes
32lakes
12
52
Star Valley, Wyoming
Best windshield out there........Heavy duty Reynolds Wrap or Amazon.com : TOTALPACK - 20" x 1000 FT Roll - 55 Gauge Thick + Hybrid technology, 4 Pack. Stretch Moving & Packing Wrap. Industrial Strength, Clear Plastic Pallet Shrink Film Ideal For Furniture, Boxes, Pallets. : Office Products. Carry a roll with you, Wrap around the front bars. Best with a second person to help hold one end to keep tight and keep the wrinkles out. Not great for the higher speeds, but slower trail riding. Keeps the mud/water from slinging up on you. Gets dirty enough take it off and wrap some more. Like tear offs for your helmet. ......im just kidding
195,897
Had me going for a minute.
Let's say you're out in the woods and get caught in a heavy rainstorm and you have your family with you. It would be nice to have a small roll of saran wrap with you so you could make a quick shelter by wrapping it around the roll cage. I like the idea, not a permanent solution but still a good idea.
rocmar
rocmar
4,741
5,778
4 CORNERS
I carry my P5...
cover..with me. .
at all times..has zipper for
drivers door access..
Reactions: joeymt33
I carry my P5...
cover..with me. .
Hey now here's a thought! take your cover to a seamstress and have them put vinyl pieces for a windshield and both windows and then you'll have an instant cab you can just throw on anytime you need it.
Reactions: rocmar and maddmax
rocmar
rocmar
4,741
5,778
4 CORNERS
HaHa...
has velcos slits for the..
...side mirrors as well...
I've used it twice. ..to ride
out a....storm...big raindrops
...size of a nickel...other was peasize
Hail..but worked
MrP500
MrP500
New Hampshire
Is it much trouble to open hood?
I have the flip open windshield from Super ATV. It is a bit of a pain to get under the hood. You have to take off the small part of the windshield. It only takes a few minutes but it's not real convenient. You can check the coolant level by looking in through the front fender. I love the windshield overall. It has three positions, closed, partially open and fully open. It's hard coated inside and out and I haven't had any issue with it scratching. If you use your head when you clean it it'll be fine. Hose it off well then use a plastic cleaner and it's fine. If you're out on the trail and it gets covered with mud just open it. It's a little pricey but I really like it.
KYhillbilly
KYhillbilly
562
1,713
Ashland, KY
I have the fold down from UTV Windshields and I really like it. I can open the hood no problem as long as the windshield isn't folded down. I also like the small piece across the top, I believe I will tint it and it will act as a sun visor as well. Have had it since April and no problem with scratches yet.
NPN
NPN
96
192
Manitoba
I bought the Super ATV flip out windshield. Very well made, no problem at full speed and the windshield open. Been through a lot of branches and twigs and no scratches yet. It's held on by very well made plastic moulded clamps with brass inserts. I carry an Allen key if I ever need to loosen the lower clamps to open the hood. Just have to accept the fact that under hood storage isn't an option with this windshield. I'd buy it again.
Reactions: MrP500
NPN
NPN
96
192
Manitoba
Have to clean the plastic ones
....with this SPECIAL Mico
fiber cloth. .blah blah blah..
I did it..for first yr...still scratches
I noticed that you have a 2500 lb Warren winch. Is that sufficient for most use or would you recommend a larger one? Thanks
Reactions: rocmar
rocmar
rocmar
4,741
5,778
4 CORNERS
Only used twice...
mine is also mounted
lower...I'm in the desert
...guys in wet areas..mount it
higher..to help keep dryer...
and easier access....
actually..warn winch....is a medium
grade winch...and would...ask around
for other guys opinion. ..how they
like wat they have...I'm not gonna
recommend. ..garbage.
