I have 2 batteries with Tru Power Isolator. When running the voltage on battery One is 14+. With off 12.8
Battery Two is about 11.7-12. I would like to put it on 3amp battery maintainer to trickle charge both batteries. Should i connect maintainer to battery One? The reason for confusion is i don't understand why battery two voltage is so low. I thought after charging battery One the isolator would charge battery Two.
Note: Only the engine Fan (marine bilge fans) are connected. Waiting to install lightbar, etc.
This is with engine off. All accessories will be on battery Two. But only fans work now.
This is with engine on
