I have a 2016 p1000-5 and my clutch is slipping. Do they sell a clutch kit or you have to buy the clutch assembly . Having a hard time just finding anything on a kit , thanks
You have to buy the whole assembly. Not sure if you’re aware but Honda has a clutch campaign going. If you bring it to your dealership you can get a new clutch and update kit free of chargeI have a 2016 p1000-5 and my clutch is slipping. Do they sell a clutch kit or you have to buy the clutch assembly . Having a hard time just finding anything on a kit , thanks
Well if it hasn’t been done they will have record of it. But either way I’d just bring it in and they should take care of itThanks I'll check with them and see , when I bought the Pioneer in 2018 it was a new 2016 that hasn't been sold and they told me the update has already been done to it.
Ok ya nothing out of ordinary. Was just curious on setup because if it has been done I haven’t heard of many issues thought weird and also making sure you didn’t have anything strange the dealer might use as reason to give you hell.Thanks . I have 30x9x14 and 3" lift . I also have done the dual battery setup , running my fan under the seat , SSV radio, led light bar and 2 pods .
...And why would you have any idea about that kind of an upgrade to a Pioneer @CumminsPusher?
Hondasxs, can you please post that on the forum..? I am buying a 2016 this week and would like to be able to tell if this has been done or not!The update has all but fixed the clutch problems. I dont recall anyone, under normal use, having problems after the update.
Tomorrow. I'll will shoot you a picture and info on how to tell if yours has the update done or not.
P1000 - VERIFIED - Official Pioneer 1000 Clutch Update!Hondasxs, can you please post that on the forum..? I am buying a 2016 this week and would like to be able to tell if this has been done or not!
Thanks!!!
Thanks!!!!P1000 - VERIFIED - Official Pioneer 1000 Clutch Update!
Instructions should be in post 1 as a pdf download.
No worries though it still quality for the campaign. A Honda dealership will be able to tell off the vin usually if it’s been done as well.Hondasxs, can you please post that on the forum..? I am buying a 2016 this week and would like to be able to tell if this has been done or not!
Thanks!!!
Excellent info! The wifes started slipping also. I suspect burnt clutch but Im checking everything I can before taking it to the dealer in the morning. Its a 2018 P1000-5. I will look to see if it has been done from the factory. Thanks for posting this.Yea. The link above has details.
The update adds this little tab by the emergancy valve. Here are a few close ups.
If you have this tab. Then you have the new clutch cover. View attachment 106964View attachment 106965
It should be done from factory. Check your oil levels before taking it in. If it is a tiny bit low, they could potentially tell you it is not covered.Excellent info! The wifes started slipping also. I suspect burnt clutch but Im checking everything I can before taking it to the dealer in the morning. Its a 2018 P1000-5. I will look to see if it has been done from the factory. Thanks for posting this.
I will check again. The engine oil and the sub tranny fluid both were at the correct levels and looked clean. From what Ive read here and there it says the engine oil will be darker and have a burnt smell to it if the clutch is burnt. It is not burnt or have a burnt smell, but its acting like what people say it acts like with a burnt clutch. Checking all the grounds and electrical quick connections tonight. Also the connections on all the computer thingys under the seat and here and there. The rpm's definetly raise before it shifts between 2nd and 3rd, and again between 4th and 5th. It also seems like when you drop it in high or low you have to give it slightly more gas to get the clutch to engage. Thanks for the input!It should be done from factory. Check your oil levels before taking it in. If it is a tiny bit low, they could potentially tell you it is not covered.
I checked, it has been done from the factory. I cleaned a bunch of connections and plugged them back in last night. No difference. Gonna load it up on the trailer in a bit and strike out for the dealer. Thanks for the help.It should be done from factory. Check your oil levels before taking it in. If it is a tiny bit low, they could potentially tell you it is not covered.
I picked mine up from the dealer service department today. It was doing the same as yours. They installed a new clutch no questions asked. Honda approved the new clutch even though they had done the housing upgrade a few months ago and the clutch was fine then.I checked, it has been done from the factory. I cleaned a bunch of connections and plugged them back in last night. No difference. Gonna load it up on the trailer in a bit and strike out for the dealer. Thanks for the help.
Im glad they did for you. The dealer called me a few hours ago to get verbal permission to tear into the tranny. They said they called Honda, and Honda said to call me, for whatever reason. He said they have done all the preliminary checks and the computer system doesnt show any codes, the oil and fluid levels were good, and not burnt, but the couldnt get through the clutch initialization process, and the next step was to open it up. He says he doesnt think the clutch is burnt, he thinks its something else. He also says that being its an '18 that has the upgraded case from the factory, that Honda wont replace the burnt clutch packs under warranty. They deem it to be 'Operator error'. I fully expect it to be a burnt clutch pack even though he thinks it isnt, but who knows. He see's Pioneer 1000s come in everyday with problems. Im keeping my fingers crossed.I picked mine up from the dealer service department today. It was doing the same as yours. They installed a new clutch no questions asked. Honda approved the new clutch even though they had done the housing upgrade a few months ago and the clutch was fine then.
I was well pleased they took care of it as I didn’t expect it and had contributed to its failure.
