P1000 Clutches burnt up
Boomboom907
596
620
Washington
I'm not even going to pretend I know how the DCT works.
I'm pretty sure on my red pioneer, it doesn't have a chance of making it to 10,000 miles on the original clutches.
It may have something to do with this.....
F67f1a9a7c3d36c471722fa8612cfa0e
085219fbfce5af58128f0cca3980ca4c
43f8578bafa5b9fb4af882920570738a
81aa4e4d4f3a33eea118ee460da5309a
I don't see the problem.
Just wondering if when I rolled, if maybe somehow oil could have ditched and that led to less lubricated clutches. Dealer told me that when you change oil there is a seperate thing that fills and you only change it once a year. Some kind of a bowl that holds oil and when you fill it up, it overflows into the rest of the engine.
Probably bro science. Idk. Seems odd to me that one mud hole was enough to kill my clutch. Maybe not.
Hopefully all that's behind me now anyways.
Sent from my Pixel XL using Tapatalk
Reactions: joeymt33
Boomboom907
596
620
Washington
@joeymt33 do you have someone take your pics or do you set up a camera
Someone else is always taking the pictures. I will typically ride with the group and we take pictures of each other. Most of us have cameras mounted on the front of the vehicles, so we're recording just about everything. The pictures above are still shots taken out of the videos.
Reactions: Boomboom907
jak9922
jak9922
hot headed wopolock
3,283
5,636
pittstown ny
ive been researching how the dct works and i still think stiffer clutch springs will help it seems most ppl that are having problems are usually riding slower or in reverse which makes sense because lower rpms=clutch slipping a stiffer spring will raise the rpms the clutchs engage and grab harder also seems like this will raise the oil pressure that is used for shifting in auto mode
Screenshot 20170222 072135
Hawk53
Hawk53
485
625
Alberta Canada
Wonder what kind of issues the car manufactures like Porche, BMW, Nissan , Audi and Volkswagon had when implementing the dual clutch transmission?
Hawk53
Hawk53
485
625
Alberta Canada
ive been researching how the dct works and i still think stiffer clutch springs will help it seems most ppl that are having problems are usually riding slower or in reverse which makes sense because lower rpms=clutch slipping a stiffer spring will raise the rpms the clutchs engage and grab harder also seems like this will raise the oil pressure that is used for shifting in auto modeView attachment 35602
I think that is just a dampening spring.
ShearerPerformance
ShearerPerformance
129
455
Space Coast FL
I have been doing the same. I worked at a shop making clutches for drag bikes for many years. But this design from Honda isn't like many others. So it's difficult to dissect.
Delton
Delton
Honda Fanboy
9,967
31,488
Middle TN
I wish these did have a single basket. I've got alot of experience with drag bikes as well. Stick a slider and a lockup on there and bingo...No more clutch problems. Ever.
jak9922
jak9922
hot headed wopolock
3,283
5,636
pittstown ny
exactly!!!!! but without actually seeing the clutches apart i can only guess but im still leaning towards the springs if honda used the identical clutch set as in the africa twin then it was designed for something almost 1/3rd the weight i do know for a fact the more pressure faster on a clutch = less slipping longer lifer and stronger faster shifts and it doesnt matter the application its just the truth about a clutch
Delton
Delton
Honda Fanboy
9,967
31,488
Middle TN
Or as @jak9922 mentioned, a good set of springs. Some gold ones from Barnett would probably solve all problems. But no, Honda had to get fancy and use oil pressure and solenoids to do a simple task. I don't want fancy on my sxs, i want tough.
It surprises me though that there are half as many clutches and they are only 2/3 the size of my 200pound dirt bikes.
Reactions: JTW and jak9922
jak9922
jak9922
hot headed wopolock
3,283
5,636
pittstown ny
i see that the oil pressure and solenoids control the actual shifting and play a part in clutch mechanics but im wondering IF!!!! the actual springs in the clutches play a part in how much pressure is applied
Reactions: Hawk53
Delton
Delton
Honda Fanboy
9,967
31,488
Middle TN
I could be wrong here but I "think" oil pressure is responsible for clamping force as well. I'd sure love to be wrong.
Reactions: CumminsPusher
It is.
Delton
Delton
Honda Fanboy
9,967
31,488
Middle TN
You should see the tiny basket/clutches they used on the cbr900rr. But there were 8 or 9 fibers too. I used Honda plates and only mod was the Barnett springs. I consistently nailed 1.40 something 60' times on a dot street tire. Honda knows how to make a clutch. Not sure what they were thinking here.
