That doesn't make any sense. Every other UTV on the market has a split engine/trans/clutch, so the oil would basically be the same as a car. The Pioneer has a single engine case for the engine and trans (plus a little case for the subtrans) and they share oil, which I would assume would mean that the oil needs to be the kind that works with clutches...
Regardless Honda still calls for a 10-30 oil. Amsoil UTV is a 10-30 oil. It's a wet clutch oil so should be fine
So are you ready to be even more confused?Ok. Here goes everyone. Believe it or not...
Just spent 20 mins on the phone with Amsoil Tech Support. We argued heatedly.
He says the Amsoil UTV 10-40 is absolutely perfectly fine for the Pioneer 1000 even though Honda calls for a 10-30, not a 10-40. He says they have the FULL BACKING OF HONDA CORP and that even Honda says the 10-40 is fine..
Now, I argued that the manual and all literature says 10-30. He still insisted Amsoil has the full backing of Honda for a 10-40 Amsoil UTV oil and I am good to go.
I questioned where this was WRITTEN. As under the Amsoil site it says under the Honda Pioneer 1000 "NO RECCOMENDED LUBRICANTS" He says website hasn't been updated yet and Amsoil will fix my motor if anything goes wrong with it (yeah, RIGHT!)
Have to say, being an Amsoil man, I am seriously doubting this information.
Any input out there???
When I emailed Amsoil directly I got two different replies. The first one said to use the 10w 30 motorcycle oil. The second said to use 0w 40 utv. Neither said to use the 10w 40 atv utv oil. Go figure that one out. So I called them and I got a different guy and he said to use the 10w 30 motorcycle oil. I asked him if it would be ok to use the 10w40 utv oil he said it should be fine but he recommended the 10w 30 motorcycle and that's what I got.
We use Honda GN-4 10-40 in everything we service in the shop, unless a customer specifies otherwise.
Well you two guys are absolutely confusing the heck out of me then. Because I have read more articles that I can count that absolutely promote synthetic oil,
most Amsoil, in the 1000?
I'm just going to write this off to everybody has their own preference. Me? I am a synthetic man![]()
Stick with the Honda GN4 oil in the Pioneer 1000, its what it was designed to use and ran in it during manufacturer testing, no need to risk running anything with too much moly, that is a death sentence to a wet clutch. But it's your money do what you wish to your machine.
I'm just going to stick with synthetic. I was stuck on Dino oil for years and was probably one of the last ones to convert over. Very hardheaded in my ways and dino has always worked fine and I was meticulous about changing it every 3000 anyway.
When I research something I do it until I'm dead. My researched showed over and over and over and yet over again, synthetic was just superior in all possible ways.
I converted and once I did I have never looked backI like the idea of a 1040 oil anyway for better protection.
Amsoil UTV 10-40 is wet clutch approved so I don't see any negatives to using it, only benefits.
May 2016
Phillips 66 Lubricants last Thursday announced that it has signed an agreement to continue supplying service-fill lubricants for the American Honda Motor Company, Inc. through 2019. Phillips 66 Lubricants will remain the exclusive provider for most Honda and Acura branded engine oil, lubricants and other vital fluids to dealers throughout the U.S.
With the clutch issues still a mystery I think I will stick with the Pro Honda GN4 oil till the dust settles on this issue. This oil is known to work so why throw another variable in to the mix?I use Honda Pro Honda GN4 4-Stroke Motor Oil 10W-30 oil and it works great with no problems over 700 miles now. Pro Honda GN4 4-Stroke Motor Oil | UTV | Rocky Mountain ATV/MC
According to the owners manual, the P1K requires oil with API service rating SG or higher and JASO T903 standard MA. (so MA1 or MA2 are also good)
I hate to tell you but the Asmoil website does list those certifications for their ATV oils but it does list them for the motorcycle oils - at least the ones I looked at.
Give those guys who answer the phones a break - they're doing the best they can with the training they received (usually not much).
