He has the hard doors on his.I need you to post a picture of those straps on the door far as I know there's no straps on the door maybe for shipment thanks
OK I see that now I think I will leave the stock doors on mineHe has the hard doors on his.
I would get ya a picture but once they have broken twice, I have moved on and replaced them with something else. It is on the hard full doors, which are a lot heavier. I'm going to try a different cable setup this time around.I need you to post a picture of those straps on the door far as I know there's no straps on the door maybe for shipment thanks
A piece of leather might work tooI would get ya a picture but once they have broken twice, I have moved on and replaced them with something else. It is on the hard full doors, which are a lot heavier. I'm going to try a different cable setup this time around.
No start bad ecm and harness, bad oil dipstick. 2 days old 9 hrs
How about some picture? ThanksNew June 17
Two days later no start problem.
Gray terminal ecm heavy corrosion damaged harness and ecm.
Oil dipstick bad casting on threads will not seal properly.
9 hrs 50 miles
Waiting on honda repair approval.
Ecm is not weather sealed!
New June 17
9 hrs 50 miles
Problems: on three occasions now it took 5-7 seconds to start and then idled rough for another 10 seconds. Hasn't done it in a while.
Driver side brake line was missing the hardware that holds it to the A-arm
Passenger side seat belt was very loose and needed to be tightened.
The high gear ratio in low range is a problem in my opinion even though in ~200 miles it hasn't caused a mechanical issue.
1. Pioneer 1000-5D
2. 12/19/2015
3. ~200
4. Deep breath....OEM front bumper/brush guard, OEM rear bumper, hard roof, hard coat two piece wind screen, fabric rear panel, bedliner, bed extender, light cubes all over, limb risers, OEM winch and winch mount, MudBuster fender flares, rear view and side view mirrors, fire extinguisher, shackles, Rotopax fuel tanks, interior lights, WetSounds ultra 6, JBL 175, pistol mount, dash mounted winch switch, snorkeled front and rear diffs, sub trans, fuel tank, park brake box, and radiator fan, CATVOS 3" lift arched and 2" Forward A-arms in the front. 3" lift arched A-arms in the rear, 30x10-14 Roctane tires on 14x7 beadlock STI HD
5. Property maintenance. Hauling firewood, pulling small trailers, several pleasure rides with deep water and hills and rocks.
6. Engine and subtrans are filled with Honda HP4S 10-30
Hey @joeymt33, I've had the same starting issue a couple times in the past 3 weeks. Did you ever figure out what was causing it? On at least one occasion it happened to me after a fairly long drive uphill in sand. When I went to start it a little while later it acted almost as if it was flooded. I pushed down on the pedal and cranked it. It acted just like you described. Once started I feathered the pedal a little through the rough idle and then it was happy. I'm not sure what I was doing prior to the second time it happened. I got it started just like I did the first time.
I never figured out what it is. It happened to me today.
Have you heard of anyone else having this happen? What really bothers me is the damn thing has only done it when I'm really far away from home. The pucker factor increases exponentially... lol
I added radio, speakers ,new rocker switches , in line fuses and in cab winch control . After all that was installed the first time I fired it up it idled funny kind of like it was flooded .revved engine a few times and it cleared up. No issues since . I think it is a electrical or computer issue causing some of this .I never figured out what it is. It happened to me today.
