P1000 CV temp??
70,225
Which is it?
It's not very wide but it sure is Short!
Or I may not drag bottom but I sure raise hell with the sides!
Reactions: BWAF
DDDonkey
What are your CV’s running temperature wise?
I’d like to have the temperature of a stock setup compared to a machine with stock axles and a HL lift.
Turf mode and 4-5 miles @ 55-60 mph on the blacktop? Mine seem to be running a little warm. Inner and outter cv’s both sides.
@Delton @Windrock1000 @joeymt33 @snuffnwhisky @CumminsPusher @ohanacreek
And anybody else running a HL lift or a stock machine with stock rear axles.
OK I just got the time and went for a quick ride for you. It is 90 degrees out and the CV's all started out between 87* and 88* and after the 4-5 mile ride between 55-60 the temps are as follows.
The temps were taken just before the rubber boot on the metal piece.
Driver inner 163* and outer (wheel) 133*
Pass inner 179* and outer 141*
I am thinking that the pass side inner was hotter because of the exhaust, but was do I know.
Awesome.. thank you! And you have a HL lift on as well?
211,870
Are you having issues with front and back, or just back. Boy, we all know you have issues with front & back, but we are talking about your S x S here! HA!
Reactions: pct and Plumber32
Yes, I have a HL on the rear and spacers on the front.
The front CV after the run was 101* both inner and outer on the fronts.
Your numbers are consistent with dad’s stock machine... guess that settles that.
Thanks again..you saved me some time and trouble putting the stock rears back in just to get the temp.
I haven’t ridden it since putting in the fronts... I took the rears out the same night and haven’t had a chance to put the new ones in. That’s tomorrow’s project
Reactions: Windrock1000
DDDonkey
No worries, I’m glad to help. At least I can contribute to this great forum every once in a while
Reactions: JTW
