P1000m5 different snorkel types
Dragon21
Dragon21
1,309
2,920
Raleigh, NC
Pros and cons to different snorkel types?
Hood- cheap, easy, outside of cab so quieter. More prone to water ingestion going fast through water? can't mount lightbar at bottom of windshield
Behind the seat- don't know much about this, but potentially noisier? But good placement. However doesn't look as clean of an install with the flex tubing
Highlifter- best looking (to me) but maybe noisy, and most costly
Thinking about the highlifter
GlockMeister
GlockMeister
The Bearded Wonder
7,606
35,593
Greenville, Mo
Highlifter takes away you beer holder:oops:.
One on eBay replaces factory air tube and goes behind the seat. @Delton has it.
Reactions: Remington and adnoh
Dragon21
Dragon21
1,309
2,920
Raleigh, NC
I just don't see how that flex tubing gets the volume you need through it.
* don't forget under the hook stealth snorkel.
Had thought about the stealth, but I like the visual of seeing where it is
Reactions: GlockMeister
GlockMeister
GlockMeister
The Bearded Wonder
7,606
35,593
Greenville, Mo
Correction, highlifter takes away my passengers beer holder haha.
I dont mind that cause ill mount the new one they supply.
It'll block part of your switch panel I believe. I personally don't trust that factory down tube. Im in the process of working up a snorkel direct of the air box. If that falls through gonna go with the eBay one.
Reactions: adnoh
Flow from factory is going to be much better than that flat flex tube.
The hood snorkel can be turned around backwards so no splash or rain. I think @CumminsPusher has his lighter mounted on the windshield.
Z
zin01
174
235
Royse City
I made mine out of 2" pvc a 2" coupling with some silicone fits perfect inside the lip on the stock air box then I cut a hole on the side of the fender/hood and ran it up the roll bar to just inside the roof. It was pretty cheap and easy to make. It does have a little growl inside when you punch it but it kinda sounds cool
Reactions: Luv4Chaos1
Byrdman
151
215
Kentucky
Has anyone toyed around with redo the tubing around the motor area? Looks just be some flex boots and stuff. It seems most try to reroute from under the hood, instead of tapping into the pipe that runs from the hood. I haven't really checked the feasibility of this myself. I noticed it yesterday when ripping out the seats and stuff to fabricate a bilge fan bracket.
322,675
I keep checking the inside down tube and everything seems fine. Don't worry about rain or anything like that as I haven't seen any real evidence of anything harmful. If a little water did make it into the tube I sure can't see it matter. It would take a whole bunch to suck up and be an issue. As noisy as the snorkel is I personally don't want that in the cabin. The filter has been super clean on every check so overall pretty happy with the snorkel
I can't speak much for the other types but the "thru the hood" model.
Water ingesting? Don't worry, I've fully tested it. This is a still shot from one of my videos.....
Bd356562729031b764ff71beba300231
As for the light bar mount, talk to @CumminsPusher. He mounted his light bar in front of it.
E
elkguide
3,377
7,964
Vermont
Looks like you're water skiing joey.
322,675
Oh that's what @ohanacreek was mentioning I was confused. The snorkel doesn't seem to mess with the light bar at all.
Here's a run with it
Reactions: Dragon21
Delton
Delton
Honda Fanboy
9,967
31,488
Middle TN
I've dove into a creek (literally) from the bank and nail the rev limiter in 6th with ease (what airflow restriction?) Back to stock in few minutes without buying a single part. And best of all, no sign of water intrusion in airbox whatsoever. Still very happy with decision to install behind the seat type. Only downside was the price but not bad compared to the HL. And I'd like to see someone snag mine on a low lying limb lol.
322,675
Those were great pictures coming off that bank!
322,675
I've been running it for quite awhile now and no air flow problems at all. It was my biggest concern before i bought it. " How exactly does a posi-trac rear end on a plymouth work? It just does "
Love Joe dirt!
Delton
Delton
Honda Fanboy
9,967
31,488
Middle TN
Mine is probably around 18 months old if not more. I've put it back stock couple of times just for the hell of it. No difference.
