906UP
Mine had the same "tweak" on the spare mount but not as bad as yours, it straightened out once I mounted the spare.My DRF extender arrived yesterday, I forgot to grab a pic of how it comes neatly wrapped up in a shipping blanket, using foam and rubber pieces to protect ends, then tightly shrink wrapped. Despite the careful packing, UPS still managed to damage it.The one thing I can count on is receiving damaged goods from UPS.
The spare tire mount, despite being heavily padded in foam, is where the damage occurred.
The force of the drop broke one side of the tack welds on the wheel stud.
There's no way I want to wait any longer to rectify this so I just got out a couple of 15" adjustable wrenches and tweaked it back the best I could.
I have a hydraulic lift table cart that made getting the bed extender into position pretty easy by myself. You can also see that I was able to get the damage mostly straightened out. I gave it the final tweaks one it was fully mounted.
The instructions call for approximately 1/16" clearance of the roll cage clamp about the factory bracket. I applied some anti-seize compound to the bolt threads. I had to remove the bolt (as suggested by DRF in his online installation instructions) from that bracket to get the back halves of the cage clamp on.
After some final tweaking (not twerking) I was able to mount up the spare.
Just to see if it would fit, I tried to install my cargo carrier. It's close but it fits.
I don't intend to run 2 spares often, just on multi day trips or when I think I may need it. Glad to have the option and I'm very impressed with the quality of the @Dirt-roadfab bed extender/spare tire carrier. Now I need to go get re-sprung for all the added weight!
