DIY Snorkel
Dasmoeturhead
Yes that's what I used
Looks good. Did you go up though the cup holder? Looks like a pvc pipe after the hose. Can you elaborate on that section of the snorkle? Thanks for you help. I'm trying to figure out the best route. I really like the under the hood setup.
Kilo427
Kilo427
1,543
6,441
The hose runs to a small piece of pvc where it squeezes behind the red plastic. I was afraid of it pinching or rubbing against the hose there. After that short 12 inch section of pvc it goes back to hose then makes a turn up to cup holder there is another section of pvc that acts to be a solid piece where the flexible section. (The big flexible hose on the outside of cup hold is from an old back pack blower. I did this because I didn't want a solid piece all the way through the dash. If I were to catch it the solid piece could torque dash and crack it so the flexible arm come out to pvc that I painted up to safari style snorkel head. All the stuff was left over from old projects or junks other than the generic China safari head snorkel intake at top. Let me know if you have other questions.
Image Image Image
Reactions: Tot and Hondasxs
Dasmoeturhead
View attachment 16669 View attachment 16670 View attachment 16671
Thank you for those pictures. You did a very nice and we'll thought job. Like you I like to see if I can make something up, with what I've got laying around. Again, that's a fine job. I have a leaf blower part I'm thinking of using also :)
Kilo427
Kilo427
1,543
6,441
Guess you could say that your snorkel is crappy and it blows. Lol
Reactions: cwalton and Tot
Chipper
Chipper
61
48
Savannah GA
What are y'all using with the snorkels for an air filter to take place of the stock air filter?
68,133
Here is my entry into the DIY simple snorkle setup.
WARNING - UPDATE, do not use the pre-filter like I did below. See this post DIY Snorkel
I have no plans to go deep. So a extension up higher up under the dash might work for me. I will be replacing the pre-filter with a new clean one so I can gauge mud entry. If a lot then back to drawing board!
E2adaa8918acbf23c8203571d69524d4
8527323aeb6f922e5cf86f2fb7b9436a
Chipper
Chipper
61
48
Savannah GA
Ok so you came up with your own version of a filter, I was curious, thank you, that was the only thing that I have not seen documented. I am not the first to say this but I really appreciate this forum, the administrator, and the people! This is a really special and amazing forum and unbelievable amounts of knowledge, I am about to get my p1000-5 and looking so forward to helping other riders just like y'all do, I am was addicted and ever since I have stepped on to you guys I am hooked even worse!!!!!
Reactions: dotman1
sharp
sharp
3,757
14,955
Tennessee
Welcome to the forum! If you have a question just ask!
Reactions: Chipper
Eltobgi
Eltobgi
4,599
15,187
North Dakota
Not that I will be going deep but because of the design flaw we really need to snorkel the 1000, is that correct to say?
I will just say... It's better to have a Snorkle and not need one than to need one and not have one;). Because of what happened to CumminsPusher I snorkels mine and extended vents upward.
Delton
Delton
Honda Fanboy
9,967
31,488
Middle TN
I have no plans to go deep. So a extension up higher up under the dash might work for me. I will be replacing the pre-filter with a new white one so I can gauge mud entry. If a lot then back to drawing board!
That is an awesome idea. This is the route I will take if I ever find a problem with my current setup. Simple and effective.
Dasmoeturhead
I'm with you. I don't plan on running in deep water. I'm just going to do it as a precautionary Mod. I thought about just terminating under the hood, but I'm concerned about engine heat. Fresh cool air is best, but you probably won't be able to feel any HP loss, if there is any. Anyway I like yours as well. Its definitely better than the stock setup.
Reactions: Stauvo
Stauvo
Stauvo
633
910
Minnesota
Yes i want to just deflect the high speed splash so i will check this out. Thanks guys!:)
68,133
Well...
I need to flag my post as a defective. Lol.
Went to check it today and the pre-filter is gone. Guess it got sucked down the pipe.
F925aacee06dcc90d4456f06ca4b72aa
