Multi Dog fence
322,675
Looking for a good electronic dog collar for invisible fence. Not a bury underground unit. Was hoping for a gps collar but the one we just got doesn’t seem to work in our yard.
Our dog continues to dig under the fence no matter what. Figured someone here has something that works for them.
Reactions: TimG
115,818
Yes sir! We have a pet safe at the cabin that makes a sphere circle up to 1/4 acre and it uses/comes with the dog collars like the buried line but this line isnt buried, its invisible. Works great.
WagginTail
WagginTail
1,585
5,880
SC
We tried all that kind of stuff. Ended up installing 4 strands of electric wire. The hound dogs won't go through that. That's the best thing we ever did and wish we had done it from the start.
Vikes79
Vikes79
SKOL!
11,771
114,142
South Dakota
  2. Talon X4 LV
Electric fence and push in stakes. I ran a wire 8” off the ground.
only took one nose to the wire. No more digging along the fence or building. Wire has been down for months and the dog won’t go anywhere near it.
322,675
Is it variable distance? Can that be placed outside
Reactions: TimG and Remington
115,818
Yes u can change the distance. We put it inside like near the door and it projects outside. You can set it outside if your camping but need 110. The mechanism isnt weatherproof. With it being inside its protected and makes the barrier outside.
TimG
TimG
OLD SKOOL
795
4,006
Southern Indiana
I had the petsafe buried line setup. It didn't really work with my labs. They would chase something across the line not thinking about it in the heat of the moment and then be stuck on the other side waiting for me to get home and get them safely back across the line. The collars were expensive and my labs were very hard on them.
I ended up building a woven wire fence 2"x4" spacing wire in the back and a white picket fence in the front yard. That worked well until we got my son's dogs to watch when he sold his house recently. His one dog is a digger and dug under the picket fence 3 or 4 times. One strand of electric wire one the bottom of the fence about 8" up did the trick. No more escaped dogs.
Reactions: Remington
KevP700-4
KevP700-4
250
615
Northern MI
We use the Pet Safe radio style. Puts out a 90’ circle, and can be adjust to smaller, 9’ is the max. Dog can go 15’ into the lake with the collar on, no problem. I know what your thinking. The unit we have has worked for 20 years and a few goldens. All you do is install a new battery in the color every 2-3 months. It will keep your dog in the yard, provided the dog understands electrocution.
  • Haha
Reactions: CID
