@SundayRdr has a 7oo not 1ooo.
Yes i seen that. I checked the stock part numbers and the bushings are the same part number. Not sure if your doors have sag in them or are loose also but i believe they will fit.
Thanks, we now have 1", 1 1/2 and 2 inch spacers!Was looking for 2in spacers for my 1000-5 had to order a set off ebay for $259 maybe worth looking into making some.
I had one bolt on the passenger side that was stubborn I soaked it with WD40 and used a ratchet to break. The others I just used my small impact.Has anyone had trouble getting the bolts loose on passenger side? I got the drivers door off easily, but the passenger side I rounded of 2 of the heads on the bolts.!!!!
I do like the bushings so far.
Due to excessive fun as @Kilo427 calls it... I had to take my front doors off to install the bushings. I used an impact but had one bolt I had to readjust how open the door was in order to get a good socket fitment.
I was.. my fenders are just a little warped.So I take it you were happy with them?
Sorry about the bolts were you guys using a 10mm?
I'm ordering rear bushings.. so yes. I was pleased. I couldn’t quite see how they would help until I pulled the old ones out and saw the difference in how they work. Good call on them!
Yes 10mm with a small battery1/4" impact. The tool they use on the passenger side was set to high!So I take it you were happy with them?
I found them! Ordering tonight. ThanksSo if I go all same wheels I would need 1inch spacer on back to match the front. I want to go 1 on the front and 2 on the back. Will that be Right? Also Rb3 I ordered bushing and will get them from you but didn't see the 2inch spacers on the web site. Did I overlook?
Sounds great! Let me know if you need any help.I am going to order door bushings and 1 inch wheel spacers tomorrow.
I have aftermarket wheels that are flat on the backside, are the lug nuts that come with the 1 inch spacers machined down so as not to protrude above the flat mounting surface?Sounds great! Let me know if you need any help.
Yes we turn down all of our lugs now to correct this issue. They will set about .020-.030 below the surface so no issues with the lug nuts. If your order is over 150 you can also use CODE: mc9c2m to get 15$ OFF!!!!I have aftermarket wheels that are flat on the backside, are the lug nuts that come with the 1 inch spacers machined down so as not to protrude above the flat mounting surface?
