P1000 Door hinges, wheels spacers....
RB3offroad
RB3offroad
1,702
4,753
Tempe, AZ
@SundayRdr has a 7oo not 1ooo.
Yes i seen that. I checked the stock part numbers and the bushings are the same part number. Not sure if your doors have sag in them or are loose also but i believe they will fit.
Bradley-Thornton
Bradley-Thornton
684
1,647
Hattiesburg MS
Was looking for 2in spacers for my 1000-5 had to order a set off ebay for $259 maybe worth looking into making some.
RB3offroad
RB3offroad
1,702
4,753
Tempe, AZ
We are looking into 2inch as well. They get pretty expensive for material. We like to maching everything down and keep tolerances tight as well as add some annodize to our aluminum. I will look into it more.
RB3offroad
RB3offroad
1,702
4,753
Tempe, AZ
Flash Sale!!! Use coupon code: nv8bfj at check out for orders over 150 and receive 10$ off your order!!!! rb3offroad.com
7,143
27,171
Has anyone had trouble getting the bolts loose on passenger side? I got the drivers door off easily, but the passenger side I rounded of 2 of the heads on the bolts.!!!!
I do like the bushings so far.
Reactions: Ragnar406
Ragnar406
Ragnar406
The Great Bald One
4,447
17,022
Bella Vista, AR
I had one bolt on the passenger side that was stubborn I soaked it with WD40 and used a ratchet to break. The others I just used my small impact.
The good news is you don’t have to mess with those installing the rear doors. It seems to me the bushings make a bigger difference installed on the rear doors.
RB3offroad
RB3offroad
1,702
4,753
Tempe, AZ
You can change the door bushings without taking off the bolt on the doors. I did this both ways. Some people are weary about taking those bolts off. You at able to pop off the eclips while its still on the door and then take the 2 pins out and remove the door. Hope this helps some people.
Due to excessive fun as @Kilo427 calls it... I had to take my front doors off to install the bushings. I used an impact but had one bolt I had to readjust how open the door was in order to get a good socket fitment.
RB3offroad
RB3offroad
1,702
4,753
Tempe, AZ
So I take it you were happy with them?
Sorry about the bolts were you guys using a 10mm?
I was.. my fenders are just a little warped.
I'm ordering rear bushings.. so yes. I was pleased. I couldn’t quite see how they would help until I pulled the old ones out and saw the difference in how they work. Good call on them!
RB3offroad
RB3offroad
1,702
4,753
Tempe, AZ
Yea, I originally just pulled the door apart just wondering what was going on in there and I was surprised to find those bushings and took measurements. They are just a cheap way to make something.
Reactions: JTW
7,143
27,171
Yes 10mm with a small battery1/4" impact. The tool they use on the passenger side was set to high!
I didn' think there was enough clearance to remove the pin without distorting the plastic. I'l look at it again. I' going to order another set for the rear doors also.
7,143
27,171
Well I finally got the passenger side door bushings installed. You can do this without removing hinges, but it will distort the plastic finder a little. Not bad but it do leave a slight mark.
Reactions: JTW
Flgator_80
Flgator_80
274
422
Lexington, Tn
So if I go all same wheels I would need 1inch spacer on back to match the front. I want to go 1 on the front and 2 on the back. Will that be Right? Also Rb3 I ordered bushing and will get them from you but didn't see the 2inch spacers on the web site. Did I overlook?
Flgator_80
Flgator_80
274
422
Lexington, Tn
I found them! Ordering tonight. Thanks
Mopower58
Mopower58
CST is the Best!
70,304
645,208
Crystal Springs,Ms.
Sounds great! Let me know if you need any help.
I have aftermarket wheels that are flat on the backside, are the lug nuts that come with the 1 inch spacers machined down so as not to protrude above the flat mounting surface?
RB3offroad
RB3offroad
1,702
4,753
Tempe, AZ
Yes we turn down all of our lugs now to correct this issue. They will set about .020-.030 below the surface so no issues with the lug nuts. If your order is over 150 you can also use CODE: mc9c2m to get 15$ OFF!!!!
