Multi Driveway maintenance
W
WildTurkey
22
39
Nantahala NC
.....It was going up WidowMaker Friday and today it had a 40Gal sprayer and a trailer behind it hauling cut trees, tomorrow it will be smoothing gravel on the driveway.
Question not too far off topic, What attachment do you use to smooth gravel? Have a similar need. Thanks!
Reactions: sharp
Reactions: sharp and trigger
158,264
103,713
I use a 6x6’ piece of chain link fence with a heavy pipe on on each end. Works great to smooth gravel.
Split them off.
I have the drag harrow because one side is smooth and can settle the high spots in the gravel the other has nice tines that will take down packed high spots before I have fresh loads delivered. Helps the fresh coat be nice and pretty.
Gator
Gator
The Most Unknown Member
2,475
10,396
Louisiana
I thought you meant potholes. I use the front bucket and drive backward to pull gravel to the pot holes.
