P1000 Dual Batteries
Little_g
Little_g
404
660
Parker, AZ
I'm going to be installing my winch within the next week or so and I was wondering how many of you have dual batteries installed? I've been looking at posts and doing some research and most are saying to install another battery to help with the winch but is it really needed? The only other accessory I have is one of those sound tubes that I have plugged into the 12v outlet. I don't plan on running anything else. Do you think I will be alright or would another battery would be the best thing to add? Any input is greatly appreciated. Thanks Everyone!
Reactions: BWAF
BWAF
BWAF
I get paid to pass gas
8,857
42,437
Carthage MO
I added a second factory battery under the hood I've got to warn 4500 winch but I've also got an amp stereo lots of Lights if the sound tubes will run on the 15 amp from the cigarette lighter you'd probably be alright till your battery gets a little older
Reactions: Little_g
13,346
64,912
Highly recommend adding another battery.
Heavy winching will draw power from your main battery, Low voltage creates lots of problems in our machines, the $200 investment or so is worth not being stuck.
BWAF
BWAF
8,857
42,437
Carthage MO
They say that transmission solenoids don't like the low voltage .
Reactions: Little_g
Little_g
Little_g
404
660
Parker, AZ
That’s what I’ve been reading a lot of when I’ve been doing the research. I’m hoping I’ll be fine for a few rides anyway. It’s not like I’m getting stuck every time or looking to get stuck. Just those “oh s***” moments happen once and a while.
Little_g
Little_g
404
660
Parker, AZ
Probably gonna happen soon just can’t make it happen right away with other bills atm. The end of the month kills me. Person should be ok for a few times. Like I said I don’t go looking to be stuck and where we ride if I know other people are getting stuck I know I will be also. It’s just those moments where it does happen. I usually get my turn 2 out of about 10 rides or so. Lol.
Reactions: BWAF
Little_g
Little_g
404
660
Parker, AZ
I have a friend who’s has his winch on for a couple years now and that’s the only thing he has as far as accessories and he’s used his quite a bit and hasn’t had any issues (so far).
Reactions: BWAF
BWAF
BWAF
8,857
42,437
Carthage MO
At least put a voltmeter in so after you winch out you can sit there and let your battery charge back up to 14.2 to 14.1
Little_g
Little_g
404
660
Parker, AZ
That was my next question/thought about letting it run for a while after. Coming from the 500 and reading all this info doesn't have me worried so to speak, I just don't wanna screw anything up lol.. Thanks for the help guys! I will definitely get a dual battery set up as soon as the funds allow.
Reactions: BWAF
BWAF
BWAF
8,857
42,437
Carthage MO
Mine runs 14.1 to 14.4 on main battery with nothing running don't know what every one else runs
OnTheJob
OnTheJob
426
925
Bristol, NY
When I winch, I see my voltmeter on my aux battery dip down as low as 10 volts and the main battery stays at 14+ volts. If you do winch on a single battery, don't use the transmission. 10 volts won't run it properly.
Reactions: lee and BWAF
BWAF
BWAF
8,857
42,437
Carthage MO
I spent like $175 I put another factory battery in it use the true isolator . 7b2a456dbd32a63438ed74a2978644b7
E
Ericthered
Eric The Red
271
522
Sparks, NV
With some minor trimming I installed 2 Lithium batteries in the original location. Charge with True Isolator. So far with 4 pulls of other (Polaris) no issues. I crawl slow, drag my belly, and get high centered. I just put in 4 Lock and get over them. But I have to turn around to get the rest over the rocks (by winch) Don't know why other 4X4s hang up. Anyway, I have full power for the main battery while the aux runs the winch. And yes, it recovers way faster than a lead acid battery. Usually in less than 10 minutes.
Reactions: BWAF
E
elkguide
3,377
7,963
Vermont
Haven't added a second battery yet and I use my winch to plow snow all winter and haven't had any issues in two years.
(do plan on adding a second battery soon though!)
13,346
64,912
Your snow plow is not a constant high load.
Activate 2-3 seconds to drop plow, push snow, lift plow 2-3 seconds.
Go get your machine stuck in babysnot mud up to the skid plates. Now try to winch out, that is a load that will kill your tranny.
Snow work is just too light a load.
jac
Do all years have the same issues? I just got a 2018 and does it have the same alternator as previous years? I have a winch but I have no plans on a second battery at the moment. I rarely will use the winch
Reactions: PAoutdoor and BWAF
Little_g
Little_g
404
660
Parker, AZ
I’m 99.9% sure that everyone is gonna recommend it as they did for me. I don’t plan on using mine a lot either but still gonna put one in just to be on the safe side. Simone did recommend that if you don’t use a second battery to leave it run and charge it back up after and not to drive it while winching out. Mine just came in today so I’m gonna install it this weekend.
Reactions: JTW and BWAF
Little_g
Little_g
404
660
Parker, AZ
Ok so I got this installed tonight and when I start my machine the light comes on within a few seconds. Then when I shut it off it doesn’t shut off. If I flick my light switch on and off then it will. Do I have something wired up wrong or is that how it is?
This one - TrueAm UTV-SBI-CK UTV Dual Battery Kit
1C000AA2 6A30 4C2A 865F 75D5590C5252
Reactions: BWAF
