![JCart](/data/avatars/m/0/959.jpg?1571643654)
JCart
Ok, I do have more questions. The configuration of the housings for both the switch and the m-ARC are a bit confusing. I can see how they designed the two halves of the housing to be fastened together but not mounted to a surface??? Also, did you use the optional start isolation wire (marked SI on the back of the m-ARC), and if so, how did you connect it to the ignition switch. And did you use the optional switch for no current draw when in storage (marked GND on the back of the m-ARC). Both have blade connectors for use with 16 awg wire. And if you did use the latter, what type of switch did you use? Thanks jrc!
I mounted mine side by side onto aluminum angle, only the switch face and M-ARC face show on front side of plate, so I didn't use the other bits of plastic. I drilled the large holes using plumbers saw on drill press, then bolted the two onto the aluminum angle.
Yes I used the optional start isolation wire. As I recall I tapped into the ignition switch harness. I'll have to check but think I unhooked the switch (keyed ignition switch) from dash. Iirc actually cut the ignition harness (in effort to make connection H2O proof) wire then using a butt connector spliced in the trigger wire also used heat shrink tube and dialectric grease to keep moisture out.
Did not use the no current draw storage circuit, as mine never sits that long...
On the passenger side of aluminum angle (can't really see it), is winch relay, then Blue Sea main switch, M-ACR, then I left a blank for other stuff.
Shows how I mounted switches to plate. Be careful not to over tighten when bolting to plate as the mount faces are slightly beveled, I used stainless fasteners with nylock nuts.
Have included full wiring circuit schematic in pdf format, I should have tapped the red/yellow wire to the starter for the impulse on the start isolation circuit.
Dropbox - 500sxswiringdiagram.pdf
Cheers,
jrc
