P1000 Duel battery kit
Ryanp502
Ryanp502
34
122
New Haven Ky
Im doing a duel battery install on my 2022 pioneer 1000. Got the true duel battery kit and it came with this? Can anyone tell me how and where it goes. It don’t show anything in the instructions about it
6F9BA339 6C0F 4208 ADB7 AA56D4DD164D B4E28AD0 7120 40CD 9DC1 05819A81DBA4
Reactions: ChadD and Lady01
Hillbillytnt
Hillbillytnt
552
2,030
Ky
That’s the relay for the dual voltmeter. Red to key on black to ground green to back of meter. The meter is controlled by ground so this relay will give it ground only when powered
bumperm
bumperm
1,907
6,789
Gardnerville, NV
So both green wires to the 2 positive plugs on the back of the voltage meter?
No, that's be back assward. One green wire goes to the negative terminal of the dual volt meter. The second green wire is a spare, and can later be used as a key-power switched ground for whatever purpose you might need. For instance, you might use it to control a relay to key-switch aux battery power to a fuse/terminal block etc. BTW, the other two terminals of the dual voltmeter get a + wire from each battery.
If you did not use that relay to switch ground for the meter, the meter would always be on and creating a small current drain on the batteries. On another note, I added a momentary push button below my meter to apply a ground to the meter so I can check battery voltages without having to turn on the key. This is also advantageous as it shows battery voltage on the main bat with no load, for as soon as you turn key on, that battery will read a lower voltage due to system load. In the pic below, you can just make out the little push button below the meter and offset towards the left a bit.
20211221 215040
Ryanp502
Ryanp502
34
122
New Haven Ky
Oh ok I got it now. Thanks for the help I appreciate it. It’s a new machine and I’m not trying to mess it up lol
Reactions: TripleB and ChadD
Mark in Northern Iowa
490
2,192
Floyd County, Iowa
kramnella.wixsite.com
Here is a thread talking about the setup.
Have a good day
Ryanp502
Ryanp502
34
122
New Haven Ky
Hey buddy one more question? If I’m hooking up a stinger relay and a fuse box, do I still need to use the one that came with the duel battery kit?
Reactions: Lady01
Hillbillytnt
Hillbillytnt
552
2,030
Ky
You can just run the red and black wires from the relay provided with the kit to your second fuse box. One green to back of voltmeter. The meter will then only be on when your fuse box is hot. This relay provides a ground to the voltmeter when powered. The stinger is going to control the hot side of your fuse box. That’s the way I have mine set up. I’m sure there are others.
Ryanp502
Ryanp502
34
122
New Haven Ky
To check for function turn key on, turn headlights on, the light should go out after a minute. That lets you know it’s working correctly. It’s normal for it to stay lit for a bit.
Thanks it went out after I did that. I was worried I did something wrong lol. I appreciate the tip
Ryanp502
Ryanp502
34
122
New Haven Ky
No problem. This is how it starts. The second fuse box makes installing the other stuff a bit easier.
That will be here Saturday. I got a 12 slot fuse box but it was to big. So I order the 6 slot with a negative bus bar attached. I figured 6 would be plenty only plan on 1 53’’ light bar for the front, 12’ reverse light, Bluetooth sound bar and a winch. That about all the powered products I’ll have.
Hillbillytnt
Hillbillytnt
552
2,030
Ky
I started with a six. I have a 12 Velcroed to the top of my 2nd battery now and it’s almost full. I have a back up harness from the club store on its way. When that gets here it will be full.
bumperm
bumperm
1,907
6,789
Gardnerville, NV
Yessir, you can do that and it'll work fine. However, if you want to also put in a momentary push button to apply ground to the dual voltmeter, so you can easily check voltages without turning things on, I would power the relay to switch your Aux fuse block circuits with key-on positive - leaving the switched negative "clean". The switched ground can be used for another chore later. here's why:
Being able to apply momentary ground to your dual voltmeter allows you to check the "unloaded" voltage of your main battery. Let's say you want to check battery voltages, you turn the key on and both aux and main voltage will be displayed on the dual meter. However, the main battery voltage will be significantly lower than the aux due to the load applied to the main (all the computer, and other onboard stuff that the engine and machine needs will load down the main so you won't get an apples to apples comparison between the two battery voltages. Sure, you can live with that, but it's also nice to be able to check batteries without turning key on when you are not planning to use the machine.
Under the dual voltmeter is a little black button that applies ground to the neg. terminal of the meter.
Note that the momentary push button would still be doable if you use a common switched ground elsewhere, aside from the meter. To do that, and not have the little button "light up" other stuff, you'd just need to add an isolation diode.
20211217 210936
Hillbillytnt
Hillbillytnt
552
2,030
Ky
I have mine set up with a master switch so the voltmeter displays when switched to the aux side. That gives me a reading on both without key on.
