P1000 Ecu Reflash for cooling fan? Or is it more!
Leukic
Leukic
314
999
Leesville, South Carolina
After an overheating issue and a post on here. I was given the knowledge of a tech notice that
Updates the fan "issue" since getting mine back here are some things that are completely different from before and after
I have had 3 chances from yesterday to today to ride around the block and give my honda hell after the ECU flash.
1- It feels like it has more low end power in high gear from a stand still mashing to the floor.
2- I noticed that in High it will redline when you floorboard it. Mine wouldn't before it would shift way sooner
3- It does not down shift as fast in High if I am running like 45 it will not shift down to the next gear when im slowing down. It kinda coasts.... alot more than I remember.
4- If I paddle shift while in Auto either up or down, It will stay in that gear ALOT longer than previous before switching back to Auto
Redmoon
Redmoon
265
455
Prescott Az.
What year is your machine? I have a 19 and like the thought of the flash changing the shift points as well as coasting more when slowing down instead of dropping through the gears. Keep us posted as you get more ride time under different conditions. I would also be interested to know if the flash improved the heat conditions.
Leukic
Leukic
314
999
Mine is a 2018. And the tech notice specifically said cooling fan issue/overheating issue. But there were alot of other changes
63,891
Thanks, @Leukic,
There have only been 1 or 2 other people report back on this "FAN" update. All have said similar things. This leads me to believe it more than a "fan" update. Plus, the fan has its own controller box. Why is the update no to it???
Thank you for your feedback.
Who else wants to get this "fan" update done? I will post full tech notes here in a little bit.
@Redmoon,
The 19's are supposed to come with this "fan" update. I know my 2019 drives totally different than my 2016. A lot smoother, longer shift points, and I can even hold it a 1 or 2 MPH without the clutch going crazy up and downshifting. And also Honda says its not available for the 2016 models.
Here is the documents.
279251ef3ec665bf07a2cb352ba3a4655a14a74a831664c1f0897a2d19a0c85a889c753e65ac9993f421d0c32c7c59ff
Reactions: pct and Plumber32
Leukic
Leukic
314
999
Thanks, @Leukic,
@Redmoon,
Yes it is a different machine. I really love the coasting and not down shifting sooo fast. and the higher rev and shift points i like
Redmoon
Redmoon
265
455
Prescott Az.
Thanks, @Leukic,
@Redmoon,
Thanks SxS. Mine drops through the gears what I consider fairly fast on deceleration. And again runs through the gears fairly fast on acceleration. When running in auto mode. I say this not having another to compare the shifting too. Maybe mine is just fine just seems fast though. HondaBob lives about 5mi. from me maybe I'll hook up with him and get his opinion.
7,145
27,191
I thought it was me! I noticed a quicker start, better acceleration and a lot more fan cycling. Happy to see it wasnt just me.
I was told the dealers and techs dont have any access to the software update particulars. It was a file that has to be downloaded and update directly to the vin specific machine.( At least on my machine)Had mine done in Feb of 19
Outacntrl
Outacntrl
111
326
Kansas
After much arguing my dealer finally agreed to flash my machine. Taking it in Saturday and will try to get a quick ride in when I leave.
Sb82
Sb82
17
30
Illinois
Is this re-flash a notice that Honda sent out, or do you just have to contact your dealer about it?
The dealer will have to do it. Just tell them your having cooling fan problems and mention the reflash.
I've been doing every 1 that comes through even if the customer hadnt requested it.
Outacntrl
Outacntrl
111
326
Kansas
2018
I contacted the only 2 dealers within an hour drive and told them it was randomly overheating and the fan would quit working. The 1st down right refused and he had no clue about the issue, but said i could bring it in and drop it off. The 2nd also wanted me to drop it off so 1 of his "skilled" techs could look at it and give a proper diagnosis. I told him I wasn't going to do that because I already knew his "skilled" tech would not be able to duplicate the issue and would say there is nothing wrong with it. He then eventually agreed to just perform the reflash and let me be on my way.
Leukic
Leukic
314
999
I pulled mine off the trailer and got on the road and floored it. Never ever would it redline in High
2018
As soon as I mentioned Jan 2019 Tech notice that @Hondasxs told me to mention he looked it up and said drop it off. Came back next morning and it was done. The actual write up on it says only cooling fan overheating issue. But it does alot more.....
Reactions: Plumber32
Jade
24
72
I have a P1000 2018 model and have not received any tech notices, other than a recall for gas pedal potentially get stuck or something. I have however overheated when climbing big hills in low for extended period of times. As such I always watch the temp and if it hits 3 bars try to get to more level area for a while in high to let things cool down. Living in Utah though, got lots and lots of mountains to climb.
Reactions: SteveinUT
Leukic
Leukic
314
999
I didnt receive one either. I searched overheating issues and then made my own post here and @Hondasxs chimed in and told me.
Outacntrl
Outacntrl
111
326
Kansas
You would not receive this in the mail. It is a "upon request" update. A good honda only dealer should know about it. A good multi line dealer will look it up. All the others suck.
Unfortunately my dealers seem to fall in the All Others category...
DanAFT
5
14
Kalifornia
I have a 2019 1000-5 we put tracks on. The second day we had it, it was idling in the yard and burped out coolant as it overheated. It did it two more times on a 20 degree day while traveling over the snow at around 29 mph. Each time it overheaded. I noticed the fan did not come on. I called my local dealer and was told to bring it in the next morning. I didn't even take it off the trailer. The tech. met me in the parking lot and did the flash. It has not overheated since. I also installed a fan over ride switch just in case. I didn't have enough time in it to notice if it change the performance.
Reactions: TripleB
DaveR
Just schedule a time to take care of the recall, and mention about the overheating issue. I took mine to monarch Honda in Orem, they where great about it. Mine was overheating randomly in the mountains too. It seems a lot better now!
