P1000m5 Engine Heat - Good or Bad?
UKNB
UKNB
54
66
Fredericton NB Canada
I'm new to SxSs and reading a lot about heat radiating up from the engine creating a lot of heat around seat, legs and feet in the SxSs of today. I'm thinking that may be a good thing during cold weather running? Can you feel warmth from the engine during cold weather?
I have a new 1000-5 LE coming next week and I'm reading about summer running and heat from engines on warm days. Is it a common mod for users to add heat shields? Is it a low speed issue? Or at normal running speeds is it the same experience?
Saw a posting here about a reversible ducted fan in the engine compartment. Neat idea.
Reactions: Shannon840
Advertisment
Ridem32
Ridem32
938
848
Terry
Hot running slow or fast. The 17 model might be better.
Reactions: UKNB
39,079
Heat shields are a fairly simple mod and can be removed for the winter. Check it out for yourself and you may not mind it. But if you do, we got your back.
17d08ef902ce1f151d6882453acf055e
Ridem32
Ridem32
938
848
Terry
I think the 17 model comes with a heat shield under the seat.
Montana
800
322
The heat under the seat is an issue but the air thru the shifters is VERY BAD both when trying to stay warn or cool. In the winter the air comming thru the shifter is cold and more air than the heater puts out. Summer is burning hot. I hope Honda has a fix by now
Reactions: AZhunter and UKNB
Jshell3
It's really not much of an upgrade. Like a wide rubber inner-tube stretched across the width of the seat.
Like the under the driver's seat on a 16, all the way across tho.
Reactions: Shannon840 and UKNB
Ridem32
Ridem32
938
848
Terry
Most of us have added seat heat shield and a blower motor ( boat bulge pump ). All SXS have heat from the motor. Ride and have fun.
Reactions: Jshell3 and UKNB
Jshell3
Where did you get this big sheet?
@Bayouownbeer sells them, precut and measured. Easy install. Like $30.
That what I did. P1000m5 - BIG BLUE <-- click that for pics!
It's not a "big sheet", tho but still quiets down the motor and seals up the heat nicely.
I also installed an Atwood 4" bilge blower. And pointed it right at the exhaust pipe. Put it on a switch. P1000m5 - BIG BLUE <--- click that for MORE pics!
Reactions: Nipper and JTW
AZhunter
AZhunter
122
154
Peoria, Arizona
You are exactly right! I get a TON of heat through the shifter and steering column holes. I've worked a lot to fix heat coming up from engine now I gotta figure out how to fix the holes in the dash to block heat from the radiator. I'm trying to like my P1k but sometimes I think, what an expensive POS! Really Honda? During the development you didn't notice the hot air blowing out the holes on the dash? I've called honda many times about the heat issues. I pretty much get the same story, "we are aware of the problem and we are addressing it". Not sure it they mean they're addressing it for future models or gonna fix the 2016/17's? What a POS. Wish I would have waited a few years this thing has too many other issues as well. Very disappointed in Honda.
You are exactly right! I get a TON of heat through the shifter and steering column holes. I've worked a lot to fix heat coming up from engine now I gotta figure out how to fix the roles in the dash to block heat from the radiator. I'm trying to like my P1k but sometimes I think what an expensive POS! Really honda? You didn't notice the hot air blowing out the holes on the dash during the developement? I've called honda many times about the heat issues. I pretty much get the same story, "we are aware of the problem and we are addressing it". Not sure it they mean they address it for future models or gonna fix the 2016/17's? What a POS. Wish I would have waited a few years this thing has too many other issues as well. Very disappointed in honda.
I noticed the heat from the shifters on my 700 and on my 1000, a LOT more when the windshield is still on which when it's on the extra bit of warm air is nice. Which for me is only during the late fall, winter, and early spring, or if I know it's going to be raining then it's just the windshield not the full cab. I have a BugBuster on the way for the rest of the time.
Because of the heat on my 700 and having the glass windshield as part of my light mounts. I set my 1000 up so with 7 quick clamps and one connector I can remove or install the glass windshield. I got the fabric mid-panel and soft doors so they were easier to remove and install. I can take the whole cab off in about 15 mins. Takes about 20 to get it on because you have to line things up and wiggle it past the @joeymt33 mounted corner lights. Which I'm going to move to the front bumper just for this reason.
Probably not all that much measurably cooler, but feels MUCH MUCH MUCH cooler because of the airflow. The windshield creates a dead air space behind it if you have the mid-panel which you need for dust.
1BadDart
1BadDart
1,199
10,352
W. KY
IMG 1755
IMG 1754
I drilled some holes in my air filter housing cover. I haven't ridden much but it seems better. I had talked to my dealer about the heat and was told Honda is recommending removing the cover. I removed mine but decided to drill the holes and reinstall after realizing the coils were out in the open with the cover removed.
Cuoutdoors
Cuoutdoors
Executive Member
4,229
15,539
Central Iowa
View attachment 42343 View attachment 42342 I drilled some holes in my air filter housing cover. I haven't ridden much but it seems better. I had talked to my dealer about the heat and was told Honda is recommending removing the cover. I removed mine but decided to drill the holes and reinstall after realizing the coils were out in the open with the cover removed.
Did you add that piece of rubber at the bottom of the housing cover?
E
elkguide
3,377
7,963
Vermont
That seems almost to simple and easy. Any other effects that you've noticed?
1BadDart
1BadDart
1,199
10,352
W. KY
Nothing I've found, like I mentioned my dealer recommended removing the cover. My reasoning (flawed or not) knowing that heat rises is tyhat the cover is a good duct and the heat comes out around the seat. This probably isn't the answer but IMO it helps.
