P500 Figured id build a snorkel
sthomp54
sthomp54
375
How did you fasten the PVC pipe to the rubber elbow on the filter box? Is it just pressed in there?
jak9922
jak9922
hot headed wopolock
3,283
5,636
pittstown ny
Alot alot alot of pvc cement shes air tight and not going any wheres
jak9922
jak9922
hot headed wopolock
3,283
5,636
pittstown ny
Yes I built the box on the back and I drilled through and bolted it onto the rear rack with 4 3/8s bolts
jak9922
jak9922
hot headed wopolock
3,283
5,636
pittstown ny
20150522 145406
