P500 First Servicing Conflicting Information
MidTN
31
86
Middle Tennessee
Greetings from Middle Tennessee. I bought a leftover but brand new 2018 P500 this spring. I love this thing, it's used for work around my property and also for play in the hills and trails through it. The wrench icon just lit up on the display telling me it's time for it's first servicing. I called the dealer I bought it from and with my discount it will cost $380 plus tax. They said that covers oil change, checking and topping off fluids, parts, and valve adjustment. Said it's 3.5 hours of work. I Called another nearby Honda dealer and they said $150 plus parts and that essentially covers an oil change and checking and topping off fluids. They said it would be silly to do a valve adjustment with only a little over 20 hours or 100 miles or so and I tend to agree. I asked them if not doing do the valve adjustment would void my warranty and they said no. Now, for $150 plus parts I can do that servicing myself. I can not do the valve adjustment. What would you do in this case? My main concern is I don't want to void the warranty I have, it just seems likeone plan is too basic and one is overkill.
IMG 20200421 172918
Alan_Vander
Alan_Vander
1,547
2,750
rosepine,la
Id take it to them the 150$ dealer and let them at it. Thats really not bad you could pretty much do it all yourself for around 70 bucks. And later if valves start clattering there are plenty of writeups and info on this forum for adjusting valves.
SILVER_ALERT
SILVER_ALERT
HONDA SXS Club Flounder
2,959
19,970
Route 66 Oklahoma
I would recommend you buy the Honda OEM oil filter and recommended Honda oil from the dealer and do it yourself. Also there are a couple of O-rings that you may or may not need, depending on whether you loose or pinch one. Get them just in case. Keep all the recipts and you will be OK warranty wise.
There is some helpful information on the forum on P500 oil change. You might want to pick up some plastic rivits, just in case you mess one up. It's no big deal even if you do.
It's not that hard to do. A little bit of a PITA the first time, just like a lot of things, but no big deal after that.
SILVER_ALERT
SILVER_ALERT
2,959
19,970
Route 66 Oklahoma
I agree that $150 is fair, if you don't want to mess with it. I also agree that a valve adjustment should not be necessary.
NitroxDiver
NitroxDiver
488
918
Concord NC
I did my own service including the valve check. If you are comfortable doing your own fluid change then I wouldn’t pay to have it done. You are not required to have the dealer do any service to maintain your warranty. If you decide to do it yourself just keep records and save your receipts. I like Honda fluids but you are also not required to use Honda fluids or filters as long as the fluids you choose meet Honda’s requirements.
HUCK
HUCK
1,047
2,315
ARIZONA
Greetings from Middle Tennessee. I bought a leftover but brand new 2018 P500 this spring. I love this thing, it's used for work around my property and also for play in the hills and trails through it. The wrench icon just lit up on the display telling me it's time for it's first servicing. I called the dealer I bought it from and with my discount it will cost $380 plus tax. They said that covers oil change, checking and topping off fluids, parts, and valve adjustment. Said it's 3.5 hours of work. I Called another nearby Honda dealer and they said $150 plus parts and that essentially covers an oil change and checking and topping off fluids. They said it would be silly to do a valve adjustment with only a little over 20 hours or 100 miles or so and I tend to agree. I asked them if not doing do the valve adjustment would void my warranty and they said no. Now, for $150 plus parts I can do that servicing myself. I can not do the valve adjustment. What would you do in this case? My main concern is I don't want to void the warranty I have, it just seems likeone plan is too basic and one is overkill.View attachment 214044
Just do it yourself . It's super easy . Don't mess with the valves .
sporttrac4x4
sporttrac4x4
1,177
2,082
ILL.
I Do my own service too but Make sure you do it correct .use the correct oil use crush washers do not over tighten things and it will go great and you will save money Have fun and good luck.
snakeriver
272
596
Clarkston Wa
I did the initial service at 100mi, and the valve adjustment at 500mi. I use to be the parts and service manager at the dealership where I bought my 500, and we never did advise a valve adjustment on a new machine unless there was some type of issue before 500mi.
Reactions: SILVER_ALERT
11,403
85,200
Do it yourself to get familiar with the machine. Much how-to info here, including cutting an access hole under the seat for all the future oil changes. I have never checked the valves in 3 yrs.
MidTN
31
86
Middle Tennessee
Thanks everyone, I appreciate all the excellent input! I'm going to do the servicing myself including the oil change, changing oil in front and rear differentials to drain out any possible metal shavings from manufacture and break-in and anything else on the Honda checklist other than the valve adjustment.
Meyers
Meyers
35
46
Madison ohio
A little frustrated now. Attempted my first oil change today. Oil drain plug extremely tight all the way out. Crush washer crushed. Removed crush washer. Oil drain plug starts but binds while tightening with my fingers. Don’t want to force it. Anybody else have this issue. Calling dealer in am.
208,135
Calling the Dealer is the best option in my feeble mind. You could get a bottom tap and chase the threads and a new bolt, be very careful if you take this upon yourself with aluminum.
Meyers
Meyers
35
46
Madison ohio
Meyers
Meyers
35
46
Madison ohio
Took machine to the dealer today. He said he will take pics and send to Honda to see if it’s covered under warranty. If covered he said probably a couple months to repair. If it’s not covered I will fix it myself. Dealer said first 2 threads bad and others pushed in. Have to wait and see I guess.
  • Sad
Reactions: CID
5,152
23,337
Well that sucks, Meyers. :( It's a rather important bolt. :oops: At least you know about it, if the dealer had done the first service they may have just looked the other way. :(
I had my Talon's first service done by the dealer to cover my butt on the warranty but they bent me right over ($$$) for doing it. :(
42,240
Does anyone know the oil drain plug bolt size? I found it for the 1000 but not the 500.
RMATV lists 12mm for a 2017 500 (didn't know your year).
Take the drain bolt and match it to a tap. Pack the flutes of the tap with grease to catch any shavings and chase the threads. Maybe even pour a quart through it afterwards.
I doubt your dealership will go to the effort of replacing a crankcase just for this issue. There are also self tapping oversized drain plugs out there that might work.
