Does anyone know the oil drain plug bolt size? I found it for the 1000 but not the 500.
Any link to where can get one??I have the best luck using a single over sized piggy back instead of tapping them out
Can get one at any parts store prefer napaAny link to where can get one??
Thanks!!U can get one at Napa take your drain plug in they should be able to help. this way the part thats messed up never has to come out again just pull the center bolt .
Not covered by warranty. The funny thing is I bought my wife a white 2020 P5. As I was loading it on the trailer I got the call..... NOT COVERED.....Took machine to the dealer today. He said he will take pics and send to Honda to see if it’s covered under warranty. If covered he said probably a couple months to repair. If it’s not covered I will fix it myself. Dealer said first 2 threads bad and others pushed in. Have to wait and see I guess.
Top pic stripped.Not covered by warranty. The funny thing is I bought my wife a white 2020 P5. As I was loading it on the trailer I got the call..... NOT COVERED.....View attachment 223516View attachment 223517
Did you use an oversize drain bolt or a Helicoil/Time-sert?Top pic stripped.
Bottom pic repair.
There's a stamping tool that spreads the outer edge that digs into the case so it won't back out.How are those secured in place, what keeps them from backing out with the drain plug?![]()
Finished the oil and filter change. Started machine and let it run for 10 minutes. Shut down. Put cardboard under machine. Will follow up in am.There's a stamping tool that spreads the outer edge that digs into the case so it won't back out.
