P500 First Servicing Conflicting Information
Meyers
Meyers
35
46
Madison ohio
A26F46CD 76FB 4F86 85B2 0106CA514157
lee
lee
Village Idiot
2,350
13,232
Springfield Ohio
Isn't Honda the one with the funky oil drain hole?
It has threads on 1/3 of the diamiter of the hole and a gap on the rest of the hole.
If you try to tap it the tap will go crooked and the drain bolt won't seal.
And, if you do get it taped, a threded insert will prevent half the oil from draining.
Maybe @HondaTech can shed some light on it.
bigshoe
bigshoe
421
1,426
I have the best luck using a single over sized piggy back instead of tapping them out
bigshoe
bigshoe
421
1,426
U can get one at Napa take your drain plug in they should be able to help. this way the part thats messed up never has to come out again just pull the center bolt .
Meyers
Meyers
35
46
Madison ohio
Took machine to the dealer today. He said he will take pics and send to Honda to see if it’s covered under warranty. If covered he said probably a couple months to repair. If it’s not covered I will fix it myself. Dealer said first 2 threads bad and others pushed in. Have to wait and see I guess.
Not covered by warranty. The funny thing is I bought my wife a white 2020 P5. As I was loading it on the trailer I got the call..... NOT COVERED.....
F8492B9E 37E0 450D B4E0 A34CC1463C63
24BCCD64 0755 4148 B75B A20EF633E882
  • Sad
Reactions: CID
5,093
22,896
How are those secured in place, what keeps them from backing out with the drain plug? 🤔
bigshoe
bigshoe
421
1,426
There's a stamping tool that spreads the outer edge that digs into the case so it won't back out.
Reactions: Meyers and CID
Meyers
Meyers
35
46
Madison ohio
Finished the oil and filter change. Started machine and let it run for 10 minutes. Shut down. Put cardboard under machine. Will follow up in am.
YouTube time sert or stripped oil drain plug and watch the vids. There are a ton.
Reactions: CID
