P1000 Flat Belly Build
ToddACimer
ToddACimer
Pioneer 1005-2
3,685
15,587
Oshkosh, Wi
I've been looking at aftermarket skid plates and decided the prices were a bit higher than I really wanted to pay especially for something I could probably build myself. I took some preliminary measurements and ordered a 4x8' sheet of 3/8" UHMW. I had the supplier cut the sheet into 2 pieces, 30x96" and 16x96"
Here's the raw material with the stock skid plate
IMG 20161230 105718995
I used a cardboard sheet to trial fit the center belly piece
IMG 20161230 111528928
IMG 20161230 124150678
I ended up with a 14" wide skid plate section under both diffs
IMG 20161230 124857261
IMG 20161230 124930446
Cutting and flaring the front fender cut out for a little foot well protection
IMG 20161230 152118170
Trial fit again
IMG 20161230 160044336
Custom UHMW bending jig, I heated 1 side until it looked wet, then started bending and then heated the otherside until it was easy to bend. After cooling it takes shape.
IMG 20161230 201616035
Fitting the drivers side footwell plate. With the center piece being 1" wider than the frame the center plate protects the inboard edge of the outer wing. Nutserts will be added to the factory rock sliders to complete the install
IMG 20161230 204527144
IMG 20161230 204533118
IMG 20161230 204543482
Second attempt to find an easy way to bend this stuff. Note the added notch in the front section of the rock slider mount
IMG 20161230 205539256
Trial fit on the passenger side
IMG 20161230 222713691
Front edge
IMG 20161230 222728984
Rear Edge and rock slider guard. The 16" material width was perfect for getting past the rockslider to offer a bit of protection from the side.
IMG 20161230 222738934
Full flat belly shot
IMG 20161230 222700521
I need to grab an M6 nutsert install tool today to wrap it up but overall the fit is better than I expected and The belly is nice and flat. Note the oil drain holes added to the center belly in the last photo.
ToddACimer
ToddACimer
Pioneer 1005-2
3,685
15,587
Oshkosh, Wi
I will probably add a hole under the front diff near the stock cut out. I may add 2-3 holes across the front of each outer panel for splash off the tires to drain. On the rear of the outsides I may add some storage boxes that fit inboard of the rear seat step and in front of the rear tires
ToddACimer
ToddACimer
Pioneer 1005-2
3,685
15,587
Oshkosh, Wi
Nutserts installed and side panels bolted up.
IMG 20161231 115733008
IMG 20161231 124504316
Full belly shot
IMG 20161231 124332310
One thing to note is the cutout on each side for the front rock rail mount. Inorder to fit tight to the firewall without a compound bend there needed to be a clearance slot
IMG 20161231 115839655
Manwell
Manwell
803
2,439
Very nice job! Thanks for sharing...
Reactions: sharp
ToddACimer
ToddACimer
Pioneer 1005-2
3,685
15,587
Oshkosh, Wi
That's the one of the best thing about this forum is posting and sharing ideas.
I agree. I'm looking forward to the growth of the aftermarket and custom built parts for the Pioneer platform. I'm hoping somebody makes a tire rack that works with the tailgate down or maybe I'll just do it myself.
Reactions: Rincon and JTW
AKRider
AKRider
1,402
3,224
Palmer, Alaska
Reactions: CumminsPusher
ToddACimer
ToddACimer
Pioneer 1005-2
3,685
15,587
Oshkosh, Wi
These would work. Just mount it higher on the ROPS.
P1000 - Honda Pioneer 1000 spare tire racks ready to ship! :)
I don't want the top of tire any higher than the top of the rear seats. I have a cargo box I like to carry behind the seat and it would be nice to have the tire rack sit in the same position as the Honda bed extender.
My 2 year plan is to do a 400-500 mile 5 day ride with my wife and 2 boys. We will need all the cargo room we can get but it should be doable
Reactions: JTW and AKRider
AKRider
AKRider
1,402
3,224
Palmer, Alaska
Doing the ROTC?
AKRider
AKRider
1,402
3,224
Palmer, Alaska
There's an eBay item that has a deeper bed extender. Maybe you could mount a tire on it?
