P500 For Sale: Rubber Noise/Heat Shield
dannyboy
dannyboy
The older I get the better I was
31
121
NW Wisconsin
  3. Talon X
Went for a nice long ride all day yesterday, first one with the Trigger Shield installed, and the difference in the cabin of the P500 is truly noticeable. Not only is noise and heat diminished, but the quantity of dust on seats and passengers seemed to be reduced as well. Thanks, trigger.
156,658
Yeah not CNC, picture perfect, factory cut but they fit and more importantly is they work. Happy to hear you like it and thanks Dan! ;)
Reactions: Chooglin
N
NHpioneer500
20
14
Hillsborough, NH
Do you have any other mods to your machine like windshield, roof or rear window?
boatman22
172
309
Woodlands TX
  3. Other Brand
trigger, put me on the list when you have time to make one? Thanks
11,317
84,091
At this rate, @trigger is gonna need another roll. He’s laying down more rubber than a Dixie dragstrip on Saturday night! For the new members, this is really the way to go after trying the other Padded/foil stuff that holds moisture.
Todd627
Todd627
56,285
615,059
MI
Well said @Mudder! I agree. The heat and noise reduction is tremendous!!
156,658
Just something I'd like to point out...if you find that it's not fitting right then you're probably doing something wrong. Put the latches through the slits, pop the seat bottom pegs through the holes and then start fitting. It should wrap around the side panel brackets, seat belts, seat back brackets and up and over the first bar on rear rack. There are several pics at the beginning of this thread showing what it should look like. Or if you're having any issues with the install, just PM me and we'll figure out what's going on. Keep in mind that these are cut for a stock P5 of all years, the only thing that may need to be modified is for accessories or something else added. Please don't go cutting on it unless you're sure it's needed.
Thanks guys. :)
156,658
Couple pics that help explain the back flaps, this way guys won't have to search the thread. If you tuck it under a box or tray, it stays put and blocks everything coming from behind you.
Rubber
Rubber At Rack
O
oldfortyfive
595
1,316
Illinois
Finally got a chance to run around with the new heat shield in place. I have to agree with others that the cab is noticeably quieter with it. Well worth the money.
Reactions: Mudder and trigger
whitebear
whitebear
20
41
Marana, AZ
Took mine out at 105 hear in Marana , AZ. Helps to muffle engine noise and but more important ,reduces the heat . I can put my hand between the seats and the shield stops all the heat from roasting your legs. Great MOD....
156,658
Sounds like it's made that ride more enjoyable and that's always a good thing. Thanks for the feedback @whitebear !
Reactions: Mudder and Eltobgi
