Did you have passengers and your normal payload in the machine when you set the sag? You're probably close but you may need a bit more. I set preload on a day when I was filling the water softener so I had about 450lbs of salt to use as payload and I didn't have to battle my passengers.I just added Viper springs to my Fox QS3 shocks . I went with 250 front and 300 rear. I’m currently at 1 1/4 preload in the front. That puts me close to the 1/3 sag overall. I was just wondering if going to 1 3/4 is too much preload. Any thoughts??
Remember that the taller you set it, the sharper your CV angles will be. That's why I'm running the Talon at spec'd ground clearance.I just got back from a test ride at 1 3/4 preload. The ride was definitely stiffer. Will drop down to 1 1/2 tomorrow and call it good for the front. I’m trying to get the best ride and maximum clearance at the same time.
TWSS 😜At some point it will start to feel stiffer.
I think you'll still want to add weight and try it again. You'll likely lose 1.5-2" of ride height with payload and Passengers. I've kept mine low too.I just got back from a test ride at 1 3/4 preload. The ride was definitely stiffer. Will drop down to 1 1/2 tomorrow and call it good for the front. I’m trying to get the best ride and maximum clearance at the same time.
what he said - just set preload at stock ride heightRemember that the taller you set it, the sharper your CV angles will be. That's why I'm running the Talon at spec'd ground clearance.
the important number is "stock ride height" - accounting for lift/tire size/etc.I believe I finally have the shock preload where I want it both front and rear. I ended up 1 1/4 in the front and about 27/32 in the rear. When I first started the post I forgot to mention that I have TTC 3 inch lift A arms. I know that changes a lot because of the angle of the CV joints. I’m going to run it like this till I can buy and install 2.0 Rhino axles, they are supposed to have better flexibility. But I just wanted to say Thanks to everyone that responded. That’s what makes this such a great place!
Never have I ever seen anyone use 80 lbs of solar salt as a booster seatDid you have passengers and your normal payload in the machine when you set the sag? You're probably close but you may need a bit more. I set preload on a day when I was filling the water softener so I had about 450lbs of salt to use as payload and I didn't have to battle my passengers.View attachment 421425
I couldn't come up with a cheaper way to put 450 lbs in the machine that wasn't going to complain about it taking too longNever have I ever seen anyone use 80 lbs of solar salt as a booster seat
Didn’t want to park beside KFC with a sign that said free fried chicken? Nevermind the salt was probably cheaper.I couldn't come up with a cheaper way to put 450 lbs in the machine that wasn't going to complain about it taking too long
I prefer to take the axle nut off and the lower a-arm. It's easier if you remove the shock and tie rod. I do not like pulling the ball joints apart or fighting the upper a-arm bolts.Can I hijack my own thread? I’ve got a front outer cv boot leaking grease . My question is , after I take everything off the hub except the A arms connections can I just remove the bolts from the lower arm and lift everything out of he way or is it better to take the upper A arm loose?
